Best transmission for a CRV/Vtec
from what i heard the LS tranny will work out the best for a good price....but who knows i might be wrong.....i know on most peoples LS/VTEC they are using a LS tranny......
98 Spec Type R tranny for all motor use would work the best, or if you can't find one of those, pick up a Y21 B16A tranny, gearing is the same except for the final drive, which is 4.40 instead of 4.785 like in the R tranny. LS trannys have taller gearing, not a bad thing if going turbo, GSR is in between, more of a mix of both LS and B16A/Type R tranny. It all depends on what the motor is going to be used for...HTH
the best is the R tranny with ats final drive.
but overall its the GSR, you won't get the wear of hi revs of the R tranny
the GSR is in the middle
LS isn't any good.
LS isn't any good.
