whats the best vtec head and ecu for my d15b2?
im doing a dpfi to mpfi swap and i wanna do a mini me while im at it so i my question is whats the best head and ecu to use? and would it be better to use the intake many of a 90 si or the same one thats on the new head?
use a d16z6 or d16y8 head
p28 ecu but you'd have to go obd1, or you can use your stock ecu and run either an afc or some other switch to activate vtec.
also the d16y8 IM is the best one for d-series.
something else: if you plan to stay obd1 try to get a d16y8 head because your obd0 dizzy will bolt right up to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr »</TD></TR><TR><TD CLASS="quote">use a d16z6 or d16y8 head
something else: if you plan to stay obd1 try to get a d16y8 head because your obd0 dizzy will bolt right up to it.</TD></TR></TABLE>
You were sooo close to being 100% right. I would avoid the AFC hack completely. I would use a z6 head with a p28 ecu. Or you can use the Y8 head, that will give you a higher compression though. Yes, the y8 IM is the best. Go obd-1 regardless if you use the Y8 or Z6 head and run it with a p28. Also, you can't run a obd-0 dizzy on a obd1 ecu. It jsut doesn't work.
cool thanx now this might seem like a dumb question but i honestly dont know. what year/ model does the y8 and the p28 come out of?
DADDYDAVE
Jun 4, 2018 07:59 AM
chrisxmichael
Jun 19, 2013 11:20 PM
SuperSi
15
Jun 24, 2006 09:57 PM
