Bad gas milage, no horse power, motor bogs after tune up
Old Feb 9, 2006 | 03:24 PM
Slacker87's Avatar
Default Bad gas milage, no horse power, motor bogs after tune up
I just recently bought a 1990 crx Si 1.6L I replaced the spark plugs with bosh platnum plus 4. Replaced the idle screw to fix idle jumping problem. The car is getting 180 a tank. From what i have heard that is really bad. There is no gas smell i dont think the car is running rich or anything. It isn't throwing any codes.
When i start out in first the car tends to bog down if i dont drag the clutch. When i shift into 2nd it drops rpm bad from 6k down to 2. Also on the interstate i can barely get the damn thing over 80. In 5th gear it has no torqe you can floor it and it doesn't move. The car has 16's on it if that makes a difference. I havn't checked the cat and I dont know where the fuel filter is. Pls help im new to honda's Oh yeah the motor has 233,000 miles on it if that helps.
Old Feb 9, 2006 | 03:58 PM
Smokinsax's Avatar
The Boot
check your timming first...then go and do a compression check, cause that motor has a lot of miles on it.
Old Feb 9, 2006 | 04:08 PM
SleepstR88's Avatar
Default Re: Bad gas milage, no horse power, motor bogs after tune up (hCrx90)
I think its time to do a swap.
Old Feb 9, 2006 | 04:10 PM
Slacker87's Avatar
Thanks, what kind of motor should i put in it? B18c1?
Old Feb 9, 2006 | 04:13 PM
SleepstR88's Avatar
That all depends on you. I dont think you could really go wrong with many applications in that kind of a ride. Look around the forum, Im sure you can come up with a few good sounding ideas. Goodluck
Old Feb 9, 2006 | 04:40 PM
AJxr's Avatar
Default Re: Bad gas milage, no horse power, motor bogs after tune up (SleepstR88)
dohc zc sounds suitable, cheap and easy. plus you can reuse your axles, tranny, linkage, mounts, etc.
Old Feb 9, 2006 | 05:48 PM
EF9ZC's Avatar
u got the wires in correct holes on dizzy?
Old Feb 9, 2006 | 06:03 PM
Slacker87's Avatar
Default Re: (EF9ZC)
i dont know how they are supposed to go in and i dont know what the stock timing is either
Old Feb 9, 2006 | 06:05 PM
Smokinsax's Avatar
The Boot
Default Re: (hCrx90)
Time to pick up a Chiltons manual for the basic stuff.
Old Feb 9, 2006 | 06:16 PM
Slacker87's Avatar
Yeah i know i guess i have to order one they dont carry it at auzo zone I just dont get why im only getting 180 miles a tank i mean it should be getting a lot better. Which motor is better for fixing up i want something in the 13's at least The car will still be driven almost 100 miles a day. So i want something that will get better gas milage.
Modified by hCrx90 at 7:27 PM 2/9/2006
Kanekz13
Jan 25, 2012 11:49 PM
saltypants
Nov 26, 2008 02:22 PM
jb0705
Mar 24, 2008 07:42 PM
Takumi Fujiwara
Apr 22, 2005 06:49 PM
ZappasOne
Jan 1, 2004 05:43 AM
