Manual Transmission Oil
Old Feb 9, 2006 | 02:48 PM
Sardawg's Avatar
Default Manual Transmission Oil
Is it possible to change the oil in my 93 EX manual tranny without pulling it from the motor? I looked at it while changing the engine oil last time and didn't see a drain plug, nor fill tube.
Also, has anyone else noticed their gas mileage drop significantly since it got colder. (those of us in northern climates) Since it started snowing back in November I've noticed mine went from average 32mpg to around 27-28.
Old Feb 9, 2006 | 03:27 PM
Chiovnidca's Avatar
Default Re: Manual Transmission Oil (Sardawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sardawg &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to change the oil in my 93 EX manual tranny without pulling it from the motor? </TD></TR></TABLE>
LOL yes. Look a little harder for the drain and fill bolts.
Old Feb 9, 2006 | 04:20 PM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sardawg &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to change the oil in my 93 EX manual tranny without pulling it from the motor? I looked at it while changing the engine oil last time and didn't see a drain plug, nor fill tube.
Also, has anyone else noticed their gas mileage drop significantly since it got colder. </TD></TR></TABLE>
Answer #1) #11 = Drain Plug #15 = Filler Plug
http://www.hondaautomotivepart...USING
Answer #2) Of Course milage is going to suffer, particularly on short trips. Every time you start an engine cold, the fuel enrichment system works to allow the engine to run until it warms up. Sometimes four (4) times longer than on a mild spring day. On a short trip, it's like driving with your choke on half the time.
P
Old Feb 9, 2006 | 04:22 PM
hondadude's Avatar
Also consider that northern states have a different 'fuel blend' in the winter time, the gasoline may have different amounts of ethanol.
Old Feb 10, 2006 | 04:17 PM
Sardawg's Avatar
Default Re: Manual Transmission Oil (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Also consider that northern states have a different 'fuel blend' in the winter time, the gasoline may have different amounts of ethanol.</TD></TR></TABLE>
Wow, wasn't aware of that with regards to fuel content during winter months.
As for the drain plug and fill plug I guess I have a little more searching to do. My wife works for Honda so I can get them to do it but if it is easy to do on my own once the snow melts I'd like to do my own work.
As for my driving habits, I take no short trips. My trip to work is 25 miles each way, all interstate 65-75mph. I checked the air filter today and it was a bit nasty so I changed it. Maybe that will help.
Old Feb 10, 2006 | 07:18 PM
devilpuppy's Avatar
the 5th gen accords are diff right?
quilter@atlanticbb.net
10
Jul 20, 2007 12:06 AM
motormike40
Aug 15, 2006 08:24 PM
The_Sober
Oct 30, 2005 07:14 AM
terrapin
Apr 7, 2004 08:58 PM
koco
Jun 29, 2003 06:29 PM
