ys1 parts qustion
Old Feb 9, 2006 | 12:48 PM
hondatuner20's Avatar
Default ys1 parts qustion
i need an input shaft bering for my cable ys1 tranny. i just read another tread that said the only cable ys1 were jdm is this true? also what car would i have to get the bearing for?
Old Feb 9, 2006 | 01:26 PM
5litereater's Avatar
Default Re: ys1 parts qustion (hondatuner20)
no.
if you need a bearing, buy a new one. you could have clearance issues due to wear patterns of a different tranny if its used.
as for the ys1 only being in japan; thats also false.
the ys1 came in the 92-93 integra gs-r (b17) for only two years and its the only cable gs-r trans as far as i know.
it also came out of 90-91 integra ls, gs, rs. correct me if im wrong but i think the trans code changed for the ls, gs, rs in 92 when the clutch became hydraulic.
hope that helps a bit...
Old Feb 9, 2006 | 01:33 PM
Default Re: ys1 parts qustion (5litereater)
ok thanks i must have been un clear in my post i wasnt planning on useing a old bearing i planned on buying one form honda directly and need to know what car to get it from but thanks for the info.
Old Feb 9, 2006 | 01:41 PM
mike-y's Avatar
92-93 integras were YS1s.
the GSR had the close ratio gears, but the bearings are the same otherwise.
Old Feb 9, 2006 | 01:52 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5litereater &raquo;</TD></TR><TR><TD CLASS="quote">no.
Integra clutches weren't hydraulic until 94
Old Feb 9, 2006 | 02:01 PM
WWDTrackRacer's Avatar
New User
Default can people not use the internet?
go to an online Acura parts dealer and look up the PN's cross reference
with other years. it's really not that hard.
and btw you can download the EPC if you look for it hard enough.
Hondatech7713
Transmission & Drivetrain
Oct 30, 2009 08:57 AM
allnaturalb16
Sep 30, 2006 10:03 AM
allnaturalb16
Sep 29, 2006 11:11 AM
virginia_dude
Jan 22, 2004 04:54 PM
