Suspension & Brakes Theory, alignment, spring rates....
About how much camber change can I expect
Old Feb 9, 2006 | 12:34 PM
cabdoctor's Avatar
Default About how much camber change can I expect
I got a really good price on a set of Eibach Sportline springs. My question is what kind of camber change could I expect. The reason i ask is Im really broke after someone did a hit and run on my car and cant afford a camber kit right now. Thanks everyone for your help.
Old Feb 9, 2006 | 12:37 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: About how much camber change can I expect (cabdoctor)
Sportlines don't drop that much (1.5-1.75 ish right) so I wouldn't worry about it.
I have Skunk2s (2-2.25 drop), no camber kit, and my tires are perfect. Just get a good alignment done
Old Feb 9, 2006 | 12:39 PM
thursday's Avatar
your toe adjustment is going to dictate tire wear more than a little negative camber. Get an alignment and dont' worry about it, as mentioned above^
also, you can put washers in the UCA on the rear to fix rear camber, this mod will cost you under $1 in parts.
Old Feb 9, 2006 | 12:40 PM
cabdoctor's Avatar
Default Re: About how much camber change can I expect (SkoundrelUSA)
Cool thanks.
Old Feb 9, 2006 | 12:45 PM
cabdoctor's Avatar
yeah I read a how-to on the rears and Im definitely going to do that. The how-to said between 1-3 washers on the bolts. Anyone know off the top of there head if I should go one or two washers for my setup? Thanks again guys
Old Feb 9, 2006 | 02:38 PM
danvuquoc's Avatar
I drive an Integra, I've had sportlines installed in the past, it gave me 2 degrees of neg camber in the front, and 1.7 degrees in the rear. I wouldn't recommend more than two washers in the rear. Depending on the thickness of the washers, a fair estimation is 1 washer for every degree of camber. I would only add one -- you'll want a LITTLE negative camber. Just be sure to get an alignment and have your toe zeroed out. I wore a set of Falken Ziex down to the thread bars in 120 miles without an alignment going from Sportlines -> H&R Race springs.
Old Feb 9, 2006 | 02:43 PM
cabdoctor's Avatar
Default Re: About how much camber change can I expect (danvuquoc)
........dang! Good thing I live around the block from an alignment shop i guess.
Old Feb 9, 2006 | 08:38 PM
.Ry's Avatar
.Ry
I had around -2.9 degree on the left rear and -2.1 on the right rear. 97 EX with 124K. Is it normal for them to be out that much? I bought camber kits for the rear since I got a hell of a deal on them from work. I havent seen a civic that bad before. Never been in an accident or anything, nothing bent, but if the upper arm cant move in or out how in the hell does it go out? I havent installed the camber kits yet, but wanted some opinions.
Old Feb 10, 2006 | 06:51 AM
danvuquoc's Avatar
Default Re: About how much camber change can I expect (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">I had around -2.9 degree on the left rear and -2.1 on the right rear. 97 EX with 124K. Is it normal for them to be out that much? I bought camber kits for the rear since I got a hell of a deal on them from work. I havent seen a civic that bad before. Never been in an accident or anything, nothing bent, but if the upper arm cant move in or out how in the hell does it go out? I havent installed the camber kits yet, but wanted some opinions.</TD></TR></TABLE>
Hmmm, have you looked at all of the bushings?
Old Feb 10, 2006 | 08:30 AM
.Ry's Avatar
.Ry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danvuquoc &raquo;</TD></TR><TR><TD CLASS="quote">
Hmmm, have you looked at all of the bushings? </TD></TR></TABLE> Not really, which ones would I be looking at mostly?
Old Feb 10, 2006 | 10:11 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">I had around -2.9 degree on the left rear and -2.1 on the right rear. 97 EX with 124K. Is it normal for them to be out that much? </TD></TR></TABLE>
I'm running over -3* camber all around on my DD without a camber kit. What's your setup?
Old Feb 10, 2006 | 10:29 AM
.Ry's Avatar
.Ry
Default Re: About how much camber change can I expect (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> Well as of now its Eibach Pro-Kit, but it was like that before the drop, maybe a little better but not much. Not sure if I should be worried, and let the kit fix it or what.
Old Feb 10, 2006 | 02:43 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote"> Well as of now its Eibach Pro-Kit, but it was like that before the drop, maybe a little better but not much. Not sure if I should be worried, and let the kit fix it or what.</TD></TR></TABLE>
That's a lot of camber if just a pro-kit, maybe something is bent.
Old Feb 10, 2006 | 03:15 PM
.Ry's Avatar
.Ry
Default Re: About how much camber change can I expect (nonsense)
Like I said it was like that before the drop. What could be bent?
shibbywhitedude
Sep 6, 2007 03:04 PM
nindoo
Honda Civic (2006 - 2015)
Jul 30, 2007 08:23 AM
vdub08
Suspension & Brakes
19
Sep 3, 2005 01:14 PM
GUNNER666
Jul 28, 2004 08:26 AM
jonoknut
Sep 15, 2002 08:10 PM
