EF ABS...Stock???
Old Feb 9, 2006 | 11:42 AM
HStockSi's Avatar
Default EF ABS...Stock???
When buying a master cylinder the I was asked whether my Si had ABS or not.
Was ABS available for a 91 Civic? How can I install them?
Any links/help are greatly appreciated.
Modified by HStockSi at 1:07 PM 2/9/2006
Old Feb 9, 2006 | 12:16 PM
Ak_ef9's Avatar
Default Re: EF ABS...Stock??? (HStockSi)
in japan it was I think.
Old Feb 10, 2006 | 04:52 PM
HStockSi's Avatar
So, no abs on EF in the states???
Old Feb 10, 2006 | 05:16 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (HStockSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HStockSi &raquo;</TD></TR><TR><TD CLASS="quote">So, no abs on EF in the states???</TD></TR></TABLE>
Correct, over sea's only
Old Feb 10, 2006 | 05:19 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (Deetz)
actualy it was ALB AnitLock Brakes available on crx exclusive if i remmimber corectly. but whos counting
Old Feb 10, 2006 | 08:25 PM
crxgator's Avatar
Default Re: (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">actualy it was ALB AnitLock Brakes available on crx exclusive if i remmimber corectly. but whos counting </TD></TR></TABLE>
it was available on more than just the exclusive...
Old Feb 10, 2006 | 08:46 PM
Deetz's Avatar
Crazy Honda Guy
Both jdm SIR and Edm VT models had the ABS option, here's a pic of the ecu for the system:
Old Feb 10, 2006 | 09:38 PM
crxforum's Avatar
Default Re: (Deetz)
My SiR's ABS is the most annoying thing on the damn car. When I get the cash Im going to take it out. Its really sensitive and will go off when on wet roads when there should be no reason to be sliding at all without it.
CRX Forum
Old Feb 11, 2006 | 01:07 AM
Twilight's Avatar
Default Re: (crxforum)
Yeah. The ALB was in European Civic/CRX VT.
Old Feb 11, 2006 | 05:47 AM
GreedyPT's Avatar
Default Re: (Twilight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight &raquo;</TD></TR><TR><TD CLASS="quote">Yeah. The ALB was in European Civic/CRX VT.</TD></TR></TABLE>
Not all. For example the portuguese model never had ALB (thank God! The system sucked!)
Old Feb 11, 2006 | 07:44 AM
Shirk's Avatar
Default Re: (GreedyPT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreedyPT &raquo;</TD></TR><TR><TD CLASS="quote">
Not all. For example the portuguese model never had ALB (thank God! The system sucked!)</TD></TR></TABLE>
I don't have it either, but I think it came as an option for Norwegian/Finnish models.
Old Feb 11, 2006 | 08:13 AM
crxgator's Avatar
Default Re: (Shirk)
i believe they came standard on UK VT's, and an option on late UK spec 16i-16v (late 89-91)...
Old Feb 11, 2006 | 08:56 AM
Hondacivic90ed's Avatar
its probably the same if not very similar to DA integras alb system, which was very problematic to say the least
Old Feb 11, 2006 | 09:09 AM
SoClose's Avatar
wonder how much those go for'z . .
Old Feb 11, 2006 | 10:04 PM
Deo's Avatar
Deo
Default Re: EF ABS...Stock??? (S o C l o s e)
I always assumed you would actually see the swap done if there was any point. I'd love ABS, but not a poor implimentation.
I am still interested in what's involved in a swap though.
Old Feb 21, 2006 | 02:48 PM
HStockSi's Avatar
For autocross in the stock class (HS) one must adhere to the cars and options available in this country only...I'll start working on my own brakes to make them as good as possible...
efhonduh
16
May 22, 2008 02:46 PM
traxxasx
Mar 2, 2008 11:31 PM
Black R
Jan 10, 2005 06:18 PM
EF-9SiR
17
Dec 6, 2002 07:46 AM
Bnjmn
25
May 18, 2002 08:37 PM
