So-Cal shop that does fender rolling
Old Feb 9, 2006 | 10:40 AM
Sean @ ESG's Avatar
Default So-Cal shop that does fender rolling
Need to roll at least my rear fenders a.s.a.p.
I don't want to risk ******* up my paint with a baseball bat, and the 500 dollar deposit on these internet rentals is ridiculous. I want to know if any of the members know of a shop around the 562 area rolls fenders.
Thanks guys!
Old Feb 9, 2006 | 12:02 PM
Sean @ ESG's Avatar
bump
steve2000's Avatar
Default Re: So-Cal shop that does fender rolling (banzai msg)
wheelchoice.com
Old Feb 10, 2006 | 11:35 AM
Sean @ ESG's Avatar
Default Re: So-Cal shop that does fender rolling (steve2000)
they're website doesnt even have a phone number?
Old Feb 10, 2006 | 03:11 PM
Airbag Club's Avatar
http://www.thewheelsupply.com
Old Feb 10, 2006 | 04:41 PM
Sean @ ESG's Avatar
thanks guys, I drove to wheel choice today (they're like 1 mile from my apt.), joji is going to do it tuesday
Old Feb 10, 2006 | 04:45 PM
Undercover_Skank's Avatar
Default Re: (banzai msg)
how much are they charging?
Old Feb 10, 2006 | 04:48 PM
B18ls*RAYON's Avatar
Rolling fenders?
Someone please post an example of what this looks like.
Old Feb 10, 2006 | 05:50 PM
ImXposed's Avatar
Needs $$ for a Hooker
Default Re: So-Cal shop that does fender rolling (B18ls)
from what i understand you cant really tell from looking at it. you're basically just bending an extra lip of metal on the inside of the fender out of the way, less wheel rub. am i right?
Old Feb 10, 2006 | 06:54 PM
Solo1B16Hatch's Avatar
Default Re: So-Cal shop that does fender rolling (ImXposed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImXposed &raquo;</TD></TR><TR><TD CLASS="quote">from what i understand you cant really tell from looking at it. you're basically just bending an extra lip of metal on the inside of the fender out of the way, less wheel rub. am i right?</TD></TR></TABLE>
You are correct sir.
Old Feb 11, 2006 | 11:38 AM
Default Re: So-Cal shop that does fender rolling (Solo1B16Hatch)
So your not bending the fending out
Old Feb 12, 2006 | 01:09 AM
Sean @ ESG's Avatar
no, its not bending the fender out...
Joji is charging $40 per fender
Old Feb 12, 2006 | 01:18 AM
Dngerzone2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ls &raquo;</TD></TR><TR><TD CLASS="quote">Rolling fenders?
Someone please post an example of what this looks like.</TD></TR></TABLE>
here my half rolled fender only rolled what i needed to then got lazy
Old Feb 12, 2006 | 02:10 AM
NrG's Avatar
NrG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ls &raquo;</TD></TR><TR><TD CLASS="quote">So your not bending the fending out</TD></TR></TABLE>
just like the other guy said. But if you're going to roll the fender beyond the stock body lines. then that's called "pulling"
Most pulling is done when extreme wheel sizing are used. I'll be pulling my rear fenders soon. Grind, heated up, rolled hardcore with a Eastwood roller; body filled, primer, paint.
Old Feb 12, 2006 | 02:20 AM
jdm jedi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg &raquo;</TD></TR><TR><TD CLASS="quote">no, its not bending the fender out...
Joji is charging $40 per fender</TD></TR></TABLE>
like airbag club mentioned.. http://www.thewheelsupply.com i believe they only charge like $25 per corner
Old Feb 12, 2006 | 05:46 AM
swifty4u's Avatar
Default Re: (jdm jedi)
$40 per wheel is rediculous when you can do it yourself in like an hour.
You can always cut the lip with metal shears a few inches apart and then bend the individual peices back.
Old Feb 12, 2006 | 06:23 AM
BACKintheDA's Avatar
Default Re: (swifty4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dngerzone2 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Feb 12, 2006 | 01:21 PM
Default Re: (BACKintheDA)
Do you have to remove your linning to do this? Will you be able to keep the wheel weld linning on after?
Old Feb 12, 2006 | 08:42 PM
Dngerzone2's Avatar
Default Re: (B18ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ls &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to remove your linning to do this? Will you be able to keep the wheel weld linning on after?</TD></TR></TABLE>
no you dont have to remove anything its like everyone said you're just bending back that extra lip on the rear fender. just go outside and touch the inside of your fender you'll see what everyone is talking about
Old Feb 13, 2006 | 10:57 PM
Sean @ ESG's Avatar
do it myself with a baseball bat? no thanks.
All the places I looked at to rent the tool are more expensive than $80 dollars, plus there is a huge deposit...
Joji is a very nice guy that knows alot about it...I'll trust him to do it
Old Feb 13, 2006 | 11:17 PM
implayaz9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm jedi &raquo;</TD></TR><TR><TD CLASS="quote">
like airbag club mentioned.. http://www.thewheelsupply.com i believe they only charge like $25 per corner</TD></TR></TABLE>
so they charge 25 bukcs for the whole inside fender or?
Old Feb 13, 2006 | 11:23 PM
CBXweb's Avatar
Sensational
Default Re: (implayaz9)
I've seen alot of 240 guys doing it alot. Gotta have some way to fit those 17x10's.
Old Feb 13, 2006 | 11:34 PM
Sean @ ESG's Avatar
i dont know...ask the guy that posted it. $25 for the whole fender seems too cheap. Might just be for the 10-2 position
Kohen
Northwest
Nov 28, 2011 06:06 PM
davidc
Southern California
Jul 6, 2009 04:26 PM
BoostKiller
Northwest (Sales)
Jan 17, 2009 08:32 AM
third lobe
Mar 5, 2008 07:48 AM
Yoshiod9
Apr 18, 2005 08:10 PM
