idling problem
Old Feb 9, 2006 | 10:27 AM
yz125rider21's Avatar
Default idling problem
Well guys I got my fuel pressure guage for car and it sits at 40 psi with the reg unplug...I so I got diff injectors put in and notice when I unplug injector 2 it doesnt drop down like 1,3,4 do as if its not really spraying at all...I know the injectors work for sure came out of a running car what should i look into next....I check the fuel pressure,timing,wires,plugs,and firing order and all is good...what should the voltage be on the obd0 plugs if i use a olm reader....please help asap thanks...
Old Feb 9, 2006 | 12:43 PM
JDMCivicEF9's Avatar
Default Re: idling problem (yz125rider21)
Check for vaccum leaks and the IACV. If you over looked those.
Old Feb 9, 2006 | 12:46 PM
EF8IGHT's Avatar
Default Re: idling problem (JDMCivicEF9)
the resistance spec for the plug wire is no more that 25k ohms resistance per wire
Old Feb 9, 2006 | 02:47 PM
what else should i look into...compression is all good just dont seem right
Hellafresh3402
Feb 27, 2013 10:56 PM
rebel1988us
37
Nov 26, 2012 08:54 AM
gunner6696
Dec 17, 2005 10:07 AM
J. Tippy
Jan 8, 2005 01:31 PM
RebelleadeR
Jun 7, 2002 12:29 AM
