Where to find...
Old Feb 9, 2006 | 09:41 AM
importfanatic17's Avatar
Default Where to find...
I have looked everywhere and I am still unable to find some JDM headlights for my 1995 Ex coupe. I don't want the JDM replicas nor do I want ebay lights, where else could I find some? Also, will the USDM harnesses on my car fit in the JDM lights? Thanks for all your help.
Old Feb 9, 2006 | 09:38 PM
masteryoda10's Avatar
Default Re: Where to find... (importfanatic17)
Well, anybody could put "JDM" on something, so watch out, as far as finding true ones, I have had a tough tima also, at least finding ones that look alright. Try http://www.tasauto.com
Old Feb 10, 2006 | 12:54 AM
darithS's Avatar
there was a guy on honda-tech that tried to sell me his real sir ones for 280, stnwagon was his name here i believe, you should hit him up, hes from san diego, 280 is a really good deal for real ones, and yes the wiring is somewhat different but im not really sure
Old Feb 10, 2006 | 08:55 PM
Thanks but I already knew about tasauto.com. That is where I just got my L.E.D. tail lamps. The headlights they have on there look tight but they are replicas. I am not really into the JDM scene, but if I get something, I want the real thing. PasswordJDM.com said they would get some in the next couple of months.
However, on a different note, the tail lamps I just bought from tasauto.com look good, but the blinker blinks ridiculously fast now. How am I supposed to fix it? I thought the wiring harness was loose or something, nope. Also, the "brake light" light on my cluster comes on after I drive for a while. WTF?!
Old Feb 11, 2006 | 06:38 PM
Fook_me_honda's Avatar
Default Re: (importfanatic17)
check the front turn signals to check if any of the wiring is loose or hanging, thats why my back turn signals blink fast too sometimes
Old Feb 13, 2006 | 04:20 AM
TouringAccord's Avatar
H-T Order of Merit
Just try looking at other JDM parts importers. I looked on JDMLand.com and found this.
Also, if your blinkers are blinking fast, look for an out light. Once on my hatch, the rear passenger side blinker started blinking fast, saw the front passenger side blinker was out so I bought new bulbs. Replaced them, and still did it. I then realized the socket was a bit loose, got a new one and it's been fine since. A fast blinker usually means one of your other blinkers are out, find the out light and make sure if it's loose wires or just a burnt out bulb.
Old Feb 13, 2006 | 04:43 AM
SpankyG's Avatar
you may need some of these to correct your fast blinker, http://autolumination.com/equalizers.htm LED's draw less current than a standard light bulb, this will cause a fast blinker, and i can cause your brake lamp light on your dash to come one.
91da9teggy
Feb 29, 2012 09:54 AM
hydrolicman
Mar 9, 2010 07:49 AM
S2k Hybrid
10
Aug 2, 2008 04:45 AM
IrregularRice
Mar 3, 2008 04:38 PM
ilcad
May 5, 2002 11:23 AM
