h22 swap in my 98 ex need info
Old Feb 9, 2006 | 08:25 AM
civichatch52687's Avatar
Default h22 swap in my 98 ex need info
alright guys i am getting ready to do a swap in te next couple weeks and i want to know , what am i going to have to do to the wireing since they are both obd2 . if u guys could help me out will be greatful
thanks
Old Feb 9, 2006 | 08:56 AM
Evil-EK's Avatar
Default Re: h22 swap in my 98 ex need info (civichatch52687)
Here you go. https://honda-tech.com/zerothread?id=650329 Read the first few pages and you will have all the info you need.
Old Feb 9, 2006 | 02:30 PM
HybridEkH22's Avatar
Im currenty doing the same thing. One problem your going to run into is the ecu. As far as emissions. where are you from? Does your state scan obdII for inspection?
Old Feb 9, 2006 | 02:49 PM
SixguN's Avatar
Default Re: h22 swap in my 98 ex need info (HybridEkH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridEkH22 &raquo;</TD></TR><TR><TD CLASS="quote">Im currenty doing the same thing. One problem your going to run into is the ecu. As far as emissions. where are you from? Does your state scan obdII for inspection?</TD></TR></TABLE>
yea, if your motor is OBD2, I don't think you can keep it OBD2 using a 97+ h22 ecu cause of the immoblizer. I could be wrong though. It has been a while since I last talked about this subject. Someone correct me?
Old Feb 9, 2006 | 03:02 PM
Default Re: h22 swap in my 98 ex need info (Sixgundone)
Yes and no. I found someone who makes a bypass chip for one type of honda immoblizer. From what ive been told, it SHOULD work on a P5P. Im expecting my P5P in the mail tomarrow. Once i get it open and check the board, i'll let you know. Other than that your gonna be stuck hunting for a 96 obd2 p13 (good luck). Or finding some way to reconstruct the immoblizer system.
Old Feb 9, 2006 | 04:39 PM
Evil-EK's Avatar
I have a 1996 H22 ecu that I will gladly sell you. Make a REASONABLE offer and I will let you know.
Old Feb 9, 2006 | 05:55 PM
i live in florida , so i dont have to worry about emissions , but wouldnt i just use the ecu that i am getting the motor from? which preludes are obd2 because, i got a good deal on 01 prelude motor and trans and ecu and wiring harnness , but besides the ecu am i going to have to do alot of wireing modifactions , if they motors are both obd2?
Old Feb 9, 2006 | 06:07 PM
You might have more problems than that. If you go for a 01 setup the transmission might have ATTS. Some sort of traction control that has to be wired up with all the electronics from the lude, plus that ecu will have an immobilizer. If you dont have to worry about any emmisions, just go with an obd1 swap. Much easier ecu wise, you can run a obd1 p13, or chipped p28 or p72.
Old Feb 9, 2006 | 07:14 PM
ok wat if i went for a 95 jdm h22 wat kind of wireing mods would i have to do then
Old Feb 9, 2006 | 08:07 PM
Default Re: (civichatch52687)
Just a matter of connecting wires and buying a obd2 ta obd1 jumper harness.
Old Feb 11, 2006 | 11:17 PM
where can i get a jumper?
Old Feb 12, 2006 | 07:45 AM
Evil-EK's Avatar
boomslang fabrication. Search Google for their website. I paid 75.00 shipped for my conversion harness.
92hondaex4door
16
May 30, 2011 04:32 AM
acord96
Aug 14, 2007 04:13 PM
hybridpatient95
Jan 27, 2005 03:00 PM
