FS: Built LS/V Short block, 1st gen B16 Top End, ACT Clutch/Fly, Z6 Bare Block, LS MESH and more!
Contact info:
Matt Langenwalter
email: bigmoneymatt@gmail.com
AIM: efhybrid89
Located in Southern California 661/818
This will become a long list of a lot of parts...I have been in this game for a while and it has gotten a little stale to me....not getting out of it completely, but scaling way down to buy into a business and make back some cash from all my projects throughout the years.
I will ship ALMOST anything at the buyers expense but, local pick ups preferred on the larger stuff (ie. blocks, heads, wheels....etc.) I am located in Santa Clarita, CA.91390...30 minutes north of LA, 15 minutes north of San Fernando Valley. I accept Paypal and Cash ONLY! I am Paypal verified and have sold numerous parts on Honda-tech.com and Hondaswap.com. I also have over 120 positive feedback on Egay! Willing to negotiate on prices and everything is BEST OFFER, but NO LOWBALLING please!!! I work 50-60 hours a week and do not have time to argue of $5 or $10…if you don’t like my prices…go look somewhere else! All parts are used, unless specified (NEW) which means 0 miles..never used!
I am also accepting trade offers for parts I need to finish one of my last projects…These will be listed at the bottom.
PICS will be taken of all items….I am getting them all together and will be added to the post or contact me if you need some sent to you for now!
!!!!!!PM me for the fastest response!!!!!!
LS/VTEC built bottom end/short block (needs pistons/rods/rings only!!!)
95 B18B1 block (83 k original miles before rebuild / 0 miles after rebuild)
bored .20 over (81.5mm final bore)
blueprinted, balanced, hot tanked, micro polished crankshaft
ACL crankshaft and connecting rod bearings (NEW)
Z10 aluminum lower block girdle(NEW)
96 P72 GSR main caps, windage tray, oil pick up, oil pan
Golden Eagle LS/Vtec Kit (sandwich adapter, oil lines, head gasket, head alignment dowels, etc.) (NEW)
ARP main studs (NEW)
OEM gasket. seals. Hondabond (NEW)
OEM Honda N1 crank pulley(NEW)
OVER $1800 invested………..asking $1400
89 B16a1 (1st gen) 90% complete top end…from the head gasket up
(needs distributor/injectors/vtec solenoid/valve cover to make 100% ready to go)
head was completely taken apart, jet washer, tolerances checked and rebuilt to
OEM specs/torques….never been milled and was pulled from a running
longblock by yours truly!…
includes:
complete valve train (valves/springs/retainers/cams
all cam caps/cams/bolts/sensors
intake manifold w/ all sensors
throttle body w/TPS
fuel rail/FPR…..asking $350
ACT Streetlite flywheel (12.5 lb)…asking $200
ACT HDSS Organic street disk with Heavy Duty pressure plate.
B series, clutch disk is for cable transmission) …asking $400
!!!!! Buy the whole package for $540!!!!
94 D16z6 Bare block….jet washed and ready to build asking $125
(4) SUPER MINT set of LS “mesh” wheels (NO TIRES) ABOSLUTELY NO CURB
RASH/SCTRATCHES!!---------------SOLD to SRCivic97!!
90 Jdm Y1 Cable tranny..non LSD
2nd and 3rd synchros have been repaled…0 miles since rebuild
No grinds/squeaks/issues whats so ever…..asking $450
Brand New 16x7 ROTA C8 bronze …1 ONLY! (older bronze, not the newer sport
bronze) with brand new 205/40/16 tire…gotta check brand…never used….was used in show
car as matching spare....never seen asphalt....asking $120
Modified by hybrid89 at 7:02 AM 2/10/2006
Matt Langenwalter
AIM: efhybrid89
includes:
throttle body w/TPS
hybrid89
Feb 21, 2006 01:52 PM
