b20 in 88 rex. good or bad idea????
Old Feb 9, 2006 | 02:53 AM
b20 crex's Avatar
Default b20 in 88 rex. good or bad idea????
i have a 88 si crx.i bought it w/a b20 on a integ ls tranny. the b20 just seems to massive for the little rex.when you look under the hood it lok like the engine is about 3-4 inches from the ground.has anyone ever done this before? or actually have one? from what i hear my rex is a freeway car but i know it would rock on the quarter mile. what do you think??? should i swap out the b20 for something else???
or you decide!!
Old Feb 9, 2006 | 04:49 AM
Jesterian's Avatar
24.243.141.75
Default Re: b20 in 88 rex. good or bad idea???? (b20 crex)
Yeah man, the b20 has way too much displacement which means you're gonna be stuck with too much torque. Who wants that?
Old Feb 9, 2006 | 05:03 AM
crxnj's Avatar
Default Re: b20 in 88 rex. good or bad idea???? (Jesterian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20 crex &raquo;</TD></TR><TR><TD CLASS="quote">i have a 88 si crx.i bought it w/a b20 on a integ ls tranny. the b20 just seems to massive for the little rex.when you look under the hood it lok like the engine is about 3-4 inches from the ground.has anyone ever done this before? or actually have one? from what i hear my rex is a freeway car but i know it would rock on the quarter mile. what do you think??? should i swap out the b20 for something else???
or you decide!!</TD></TR></TABLE>
Damn you're making the b20 sound like a v8 or something..It's the same size externally as a B18a/b motor except the intake manifold..
Old Feb 9, 2006 | 05:07 AM
Andrew Marquis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">you're gonna be stuck with too much torque. Who wants that?</TD></TR></TABLE>
right!
too much torque = NO traction what-so-ever in such a light car
Old Feb 9, 2006 | 08:14 AM
91whiteZCrex's Avatar
Default Re: b20 in 88 rex. good or bad idea???? (bakerboy4679)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bakerboy4679 &raquo;</TD></TR><TR><TD CLASS="quote">
right!
too much torque = NO traction what-so-ever in such a light car</TD></TR></TABLE>
if you have the right suspension setup, and know how to drive, this shouldnt be a problem. your guys must have slow *** ef's if you dont know about how to fix traction problems. any motor that you put in a crx is going to spin if you cant drive and understand how the wheels spin. if you hvae a good *** tire, that takes care of a good ammount of wheelspin. mybuddie that owns a shop had a 90 hf with a built b20/vtec and he spun thro first and half thro second if he launched, if he did a first gear roll with his bfg's drag rad's on then he spun a litlle bit, and took off like a damn rocket. u can never have to much torqe in a honda.
Old Feb 9, 2006 | 09:22 AM
Smokinsax's Avatar
The Boot
Default Re: b20 in 88 rex. good or bad idea???? (91whiteZCrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex &raquo;</TD></TR><TR><TD CLASS="quote">if you have the right suspension setup, and know how to drive, this shouldnt be a problem. your guys must have slow *** ef's if you dont know about how to fix traction problems. any motor that you put in a crx is going to spin if you cant drive and understand how the wheels spin. if you hvae a good *** tire, that takes care of a good ammount of wheelspin. mybuddie that owns a shop had a 90 hf with a built b20/vtec and he spun thro first and half thro second if he launched, if he did a first gear roll with his bfg's drag rad's on then he spun a litlle bit, and took off like a damn rocket. u can never have to much torqe in a honda.</TD></TR></TABLE>
im pretty sure they were being sarcastic.
Old Feb 9, 2006 | 09:36 AM
Default Re: b20 in 88 rex. good or bad idea???? (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">
im pretty sure they were being sarcastic. </TD></TR></TABLE>
i hope they were, im not being a dick im just explaining to the guy who made the thread, but you never know with some people on here
Old Feb 9, 2006 | 10:05 AM
AJxr's Avatar
keep the b20, cr-vtec.
Old Feb 9, 2006 | 10:55 AM
Jesterian's Avatar
24.243.141.75
Default Re: b20 in 88 rex. good or bad idea???? (AJxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure they were being sarcastic. </TD></TR></TABLE>
I'm pretty sure you're right.. If you have a b20 already, you should think about buying a b16 head and slapping it on there. There's absolutely no reason to switch the blocks out though.
Old Feb 9, 2006 | 11:52 AM
I'm pretty sure you're right.. If you have a b20 already, you should think about buying a b16 head and slapping it on there. There's absolutely no reason to switch the blocks out though. </TD></TR></TABLE>
glad to hear you say that, you should just get the whole type-r head...intakemani throttle body, head cams springs everything. and then you would be rather happy. or port the b16
Old Feb 9, 2006 | 11:01 PM
b20 crex's Avatar
thank you guys for all you help.i really appreciate it . but if anyone as any ideas on how to make it even better.keep on tossing ideas this way. thanks again
Old Feb 10, 2006 | 04:12 AM
b20 crex's Avatar
glad to hear you say that, you should just get the whole type-r head...intakemani throttle body, head cams springs everything. and then you would be rather happy. or port the b16</TD></TR></TABLE>
would it be easy for me to put on the whole type-r on or should i just go with the b16 head???mind you i want to do it all myself.
Old Feb 10, 2006 | 08:57 AM
you have to do the same thing to put either on, its just how much money you have. the b16 head will be more expensive to make it as good as the itr. you cannot beat the quailty of oem honda thats why i said itr
Lsgsr94
Mid-Atlantic (Sales)
Oct 18, 2007 02:17 AM
xd69
Sep 10, 2004 03:48 PM
