H series water pumps
Old Feb 9, 2006 | 01:53 AM
Jynxeh's Avatar
Default H series water pumps
Do all the H series engines use the same water pump through out the range for the same generations?
Including Vtec/non-Vtec?
If I get the H23(non-vtec) pump from my Rover dealer its half the price of the H22(vtec) from Honda.
From what I can see on parts catologue and inspection they are identical, I mean there isnt much in them, just wanted to check there is no small cast differences.
Thanks.
Old Feb 9, 2006 | 04:05 AM
Honda318dx's Avatar
Default Re: H series water pumps (Jynxeh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jynxeh &raquo;</TD></TR><TR><TD CLASS="quote">Do all the H series engines use the same water pump through out the range for the same generations?
Thanks.</TD></TR></TABLE>
Non VTEC water pump gears are different from VTEC water pump gears.. Do NOT use a Non VTEC waterpump on a VTEC engine, even if it will bolt up. The # and size of the teeth is different, so it won't match the timing belt.
Old Feb 9, 2006 | 04:20 AM
Jynxeh's Avatar
Great reply thank you.
Guess its £80 at Honda then
lolv8s
Mar 26, 2017 08:06 PM
43!
Oct 1, 2014 01:10 PM
CeeJayy
Jul 10, 2007 06:32 PM
mugenwannabe
Aug 8, 2006 01:19 PM
donkiman
Aug 8, 2004 06:41 PM
