Rear Sway Bar w/ Stock Suspension
I'm picking up my 5g SH in a week. I'm not ready to spend money on the main suspension yet (I want to do it right the first time). What do you guys think of getting a thicker rear sway (anti-roll) bar and using it with stock suspension to further tighten things up and reduce understeer? TIA.
IMO, the 3 most important things are tires, shocks or struts and the rear sway bar. I think the rear sway bar will help the most. Think about a progress bar with ugraded endlinks.
yeah, that wouldn't be a problem on a prelude.
dc/eg/ek would have subframe tearout potential esp with stock springs, but the lude swaybar setup is different and a little more sturdy.
I would not suggest going to a bar bigger then 25mm if you still run stock suspension, the mounts CAN rip out on preludes if to big of a rear bar is used on the soft, stock prelude suspension.
