FUEL pump relay on 4gen, Where is it?
Old Feb 8, 2006 | 08:57 PM
bb4socal's Avatar
Default FUEL pump relay on 4gen, Where is it?
Im gonna do a compression test and i was informed that its best to do it with the Fuel Pump Relay pulled to avoid flooding the engine. Where is it located?
Old Feb 8, 2006 | 09:30 PM
mgags7's Avatar
just pull the fuel pump fuse
the fuel pump has no relay as far as i know, the main relay does that job....
Old Feb 8, 2006 | 09:34 PM
bb4socal's Avatar
ohh ok....where is the fuel pump fuse at?
Old Feb 8, 2006 | 09:37 PM
mgags7's Avatar
like most fuses....its in the fusebox
Old Feb 8, 2006 | 10:43 PM
bb4socal's Avatar
Default Re: (silverlude15)
yeha your right...i did title this fuel pump relay, but some one suggested just taking off the fuse, so that swhat im trying to figure out. I cant double check right now, but i honestly dont remember there being a specific Fuel pump fuse in the underhood or underdash fuse "boxes". Ill double check in the morning i guess.
Old Feb 9, 2006 | 08:07 AM
flip1199's Avatar
relay is under the drivers side dash. isnt the pump fuse on top of the pump? can't really remember it's been years since i last looked.
Old Feb 9, 2006 | 08:51 AM
mgags7's Avatar
the relay that controls the fuel pump is the main relay, which is inline with the ignition switch, and is located under the driver side dash
the fuse for the fuel pump is in the fusebox under the driver side dash, it says it on the cover
Old Feb 9, 2006 | 05:04 PM
bb4socal's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">the fuse for the fuel pump is in the fusebox under the driver side dash, it says it on the cover</TD></TR></TABLE>
OK ok...am i still wrong? i dont see it do you???
Old Feb 9, 2006 | 06:04 PM
mgags7's Avatar
i had the ecu fuse in mind...my bad
i will search the helms for compression test procedure
Old Feb 10, 2006 | 11:16 AM
bb4socal's Avatar
well if you find anything about not floodind the engine, let me know. This is become a bit of a pain...lol...ohh well i guess
Old Feb 10, 2006 | 01:04 PM
bb4socal's Avatar
Well...ive been searchin around HT.com and ive read a couple times to just pull the ECU fuse(s). So i guess im going to try that.
Old Feb 11, 2006 | 06:22 PM
92vteclude's Avatar
Default Re: (bb4socal)
I did a compressin test on my car today and just jumped the starter... this doesnt activate the ecu or anything else, it just cranks the motor...
Scarekrow
Oct 11, 2015 08:05 PM
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
m.glisson003
Oct 31, 2011 05:53 PM
snzh22
Aug 8, 2007 04:53 PM
jabenne
Nov 8, 2003 11:56 AM
