MEtal rubbing white turning...
Old Feb 8, 2006 | 08:10 PM
p-p-porkchop's Avatar
Default MEtal rubbing white turning...
Hey a friend of mine has a 2000 LS and his car is making this rubbing noise everytime he turns his wheels. Sounds like metal rubbing. It wasnt as bad at first but its slowly getting worse. He said he already replaced his brakes. WHATS THIS RUBBING NOISE?
Old Feb 8, 2006 | 10:31 PM
no2unenolife's Avatar
is he lowered at all
Old Feb 9, 2006 | 01:22 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (no2unenolife)
Axels, or it could be your wheel bearings. just a thought.
Old Feb 9, 2006 | 02:21 AM
Default Re: (wrx-killer-Sti eater)
yeah his car is dropped about 1.75-2 in the front. and 1.5 in the rear. Im not sure. He just has some progressive springs on stock shocks.
Old Feb 9, 2006 | 07:25 PM
Sam92Teg's Avatar
Default Re: (jdmdc2jdm)
I bet it is the dust sheild behind the rotors scraping. Just pull the tire and bend it back off the rotor some with your hands.
Old Feb 9, 2006 | 07:38 PM
iwantturbo's Avatar
Default Re: MEtal rubbing white turning... (jdmdc2jdm)
yeah cud be wheel bearings... happened to me about 2 months ago... id hear the sound every time i turned to the right... even if i turned just a little bit i wud start hearing it... when i turn left, the car sounds normal
Old Feb 9, 2006 | 08:22 PM
Uncle Willie's Avatar
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">I bet it is the dust sheild behind the rotors scraping. Just pull the tire and bend it back off the rotor some with your hands.</TD></TR></TABLE>
YUP this will solve problem.
Old Feb 9, 2006 | 08:27 PM
bitz95civ's Avatar
Default Re: (RIP Indian Larry)
It could also be the ball joint. I had a metal scraping noise and then one day i was going out of a parking lot and my ball joint came out pulling my cv joint out of the tranny
Old Feb 9, 2006 | 08:34 PM
numbnuts22715's Avatar
Default Re: MEtal rubbing white turning... (lsturbojk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbojk &raquo;</TD></TR><TR><TD CLASS="quote">yeah cud be wheel bearings... happened to me about 2 months ago... id hear the sound every time i turned to the right... even if i turned just a little bit i wud start hearing it... when i turn left, the car sounds normal</TD></TR></TABLE>
thats what happened to me.. but my storys a lot gayer..
I had to replace a lug, tand to do that, you have to remove the hub, and when you put the hub back on, its recomended to replace the wheel bearings as well. sO I got a shop to press in the wheel bearing and they messed it up, so I get to go buy a new one.. over 100 bucks on wheel bearings just because of a stupid piece of **** lug
Don Jefe
Apr 12, 2006 01:31 PM
integra1020
11
Feb 20, 2006 02:56 PM
jadugartir
Aug 5, 2005 10:23 PM
coot_er
Mar 29, 2005 03:47 AM
Origin
Aug 29, 2004 10:16 PM
