Which Exhaust???
Old Mar 26, 2002 | 12:00 AM
Wild Willy's Avatar
Default Which Exhaust???
I am look for a all around good exhaust. Looks, performance, and sound. I do
not want a real loud anoying sound. I have a supercharger if it matters.
Old Mar 26, 2002 | 12:04 AM
Reid's Avatar
Global Moderator
Default Re: Which Exhaust??? (Wild *****)
3" Thermal Stealth. You can't have your cake and eat it too, but that's about as best you can do in the power/loudness tradeoff.
Old Mar 26, 2002 | 12:19 AM
ITRinEJ1's Avatar
Default Re: Which Exhaust??? (Reid)
i'd definitely 2nd that
Old Mar 26, 2002 | 12:37 AM
SMSP's Avatar
Plus, if you remove you heat shield at teh end of the tunnel you should be able to install a 3" resonator also. They average about 6" in diameter, hence the reason the heat shield needs to be removed.
Old Mar 26, 2002 | 02:02 AM
mafay2's Avatar
New User
Default Re: Which Exhaust??? (SMSP)
Kakimoto R 70mm catback!!
Old Mar 26, 2002 | 02:28 AM
hybrider's Avatar
Default Re: Which Exhaust??? (mafay2)
custom
Old Mar 26, 2002 | 04:52 AM
1GreyTeg's Avatar
Anyone gonna suggest a HF Cat for him too?
I know the Carsound 94006 fits 2.5" but, which one fits the 3"?
A.
Old Mar 26, 2002 | 05:19 AM
MPH's Avatar
MPH
New User
Default Re: Which Exhaust??? (hybrider93)
custom
Old Mar 26, 2002 | 05:23 AM
SMSP's Avatar
Default Re: Which Exhaust??? (1GreyTeg)
A.
If he's FI then he maybe running the Kamikaze header. I've built 3" cats (94009) with 2-1/2" x 3" adapter welded to the inlet of the cat to bolt right up to the Kami header. If he has a 3" collector then chances are he'll need a flex tube to connect to the collector which then could be welded or bolted to the cat. Usually the Thermal B pipe needs to be shortened with either of these routes.
Old Mar 26, 2002 | 05:38 AM
TypeR0149's Avatar
Custom 2.5 1 22 inch magnaflow resonator, and a magnaflow 2.5inch muffler. top it off with the 2.5 inch stock Type R tip. and you have a great "anti rice" exhaust
anytime your Tip is bigger than the Piping it is GAY
Old Mar 26, 2002 | 06:59 AM
00MRSi's Avatar
SMSP, can you please post your email address. I have some questions regarding JDM 4-1 header and carsound cat.
Old Mar 26, 2002 | 08:28 AM
Reid's Avatar
Global Moderator
Default Re: Which Exhaust??? (00MRSi)
It's in his profile...
Old Mar 26, 2002 | 08:48 AM
AllMotorITR's Avatar
New User
SMSP or Hytech Header, Type One B-Pipe, and Spoon N1 Axleback...
Old Mar 26, 2002 | 08:50 AM
AssPenny's Avatar
Default Re: Which Exhaust??? (1 FAST R)
How about the hytech twin loop... anybody know when that bitch is suppost to come out? Thought it was like begining of Feb?
Old Mar 26, 2002 | 08:52 AM
Reid's Avatar
Global Moderator
Default Re: Which Exhaust??? (AssPenny)
John should have those available in a short amount of time. I saw the first batch of muffler canisters while I was up there in late Feb.
Old Mar 26, 2002 | 08:54 AM
Reid's Avatar
Global Moderator
I'm sure Hytech and SMSP could make a header to fit your needs, but the b pipe and muffler have too small of an ID for a supercharged motor to breath.
Old Mar 26, 2002 | 09:43 AM
00MRSi's Avatar
Reid thanks man. Sorry, Newbie mistakes..
Old Mar 26, 2002 | 11:39 AM
2qwik2nv's Avatar
I've got a 5Zigen Fireball. A very nice low sound. It isn't the tinny sound that's typical of b16's or base b18's.
I beg of you, do not do Ractive!!!!!!
123Four
Sep 8, 2006 05:32 AM
b18sihatch
Jun 2, 2006 06:04 AM
BlueLude 94
Apr 27, 2006 04:46 PM
kay_animation
Feb 8, 2003 04:25 PM
