I need help on getting a h22 engine im kinda new to the whole engine deal
Yeah so my stock engine is kind of goin out on me and it has over 200,000 miles on it so yeah "new engine" time and im interested in getting the h22. what do yall think?
Modified by BigDevin87 at 8:10 PM 2/8/2006
masterbating really does effect eyesight :-P just kidding , anyways a H22 is farely easy for 94-97 accords im not sure if its the same .
I replied to your other post to.The h22 is a good way to go.I'm taking the hard road and putting together a turbo setup.
this place sells h22s fairly cheap.and shipping isn't to bad either
http://www.japaneseengineimpor...1.htm
Modified by Dmc1 at 6:20 AM 2/9/2006
as far as fitting an h22 into your 92, there is no problem they fit perfectly. from what ive heard on other forums european accords actually come with the h22 engine already. type r h22s. could be wrong but as i recall ive heard that on cb7tuner.com. check that out.
Yeah on a 92 accord a h22 is almost a direct bolt in.you don't have to change any pins on the ecu.use the prelude mounts and your good.I think you have to use the f22s fuel rail though.Not 100 percent on that but seems like i remember hearing that.
neronian
Mar 28, 2004 12:21 PM
neronian
Mar 26, 2004 10:56 AM
