Does anyone know how to remove the swaybar endlink?
Old Feb 8, 2006 | 06:25 PM
Dai_Ca_Vietnam_H22a4's Avatar
Default Does anyone know how to remove the swaybar endlink?
I have a 97' Honda prleude. My right swaybar endlink is bent for some particular reason. I tries to remove the endlink but the nut and bolt keep on spinning. I have no way of hold the bolt still so that I can remove the nut. Is there a special tool to remove this?
Old Feb 8, 2006 | 06:39 PM
Jos3ph's Avatar
Default Re: Does anyone know how to remove the swaybar endlink? (Dai_Ca_Vietnam_H22a4)
on the end of the threaded bolt (side with the nut attached) there should be a hole to stick a hex key wrench to hold the bolt in place so you can remove the nut. i don't remember what size hex key wrench though.
Old Feb 8, 2006 | 06:42 PM
Default Re: Does anyone know how to remove the swaybar endlink? (Jos3ph)
I'm so stupid. I over look that there was a hex keyhole.. Thanks..
Old Feb 8, 2006 | 07:11 PM
98Luder's Avatar
careful those things like to strip
Old Feb 9, 2006 | 02:09 PM
Default Re: Does anyone know how to remove the swaybar endlink? (98Luder)
Thanks 98Luder.. I will remember to spray WD-40 before I work on them.
grumblemarc
28
Oct 24, 2011 05:21 PM
Spoon_Si-R
20
Jan 3, 2007 03:25 PM
cc11386
Nov 2, 2005 01:31 PM
ANGELIQUE
10
Apr 11, 2004 01:35 PM
