Any one got PICS?
I want to know if any one has hatch PICS of there systems?I have a good Idea of what I'm gonna do.Just want to see if there is any thing similar or that will help me set mine up.I know how I'm gonna set up my sub,just not sure were and how I'm going to set up my Amps.Yes ,I know that adding subs,amps, etc.,adds weight but I'm setting up my sub & enclosure in a way that I can easily pull the box out of the car, before I hit the track.
Thanks-HC4G
Thanks-HC4G
I had a bunch of pics of mine, but i must've deleted them.... I built an enclosure for a single 10" that fits in my spare tire well. I built the sides and top out of 3/4" mdf, lined the spare tire well with aluminum foil, set the box in, and poured fiberglass resin and cloth in to make the bottom (about 1/2 in thick.) Then i made a top cover board out of 1/2" mdf with a grille flushed in over the sub, and layed the factory trunk liner over that.
Invisible sub thats removeable on race day.
As far as the amps go, I mounted mine under the front seats. I had to "modify" the bottoms of the seats with a hammer to make enough room for them, but it works fine now, and I barely notice the fact that my butt sits a little firmer now.
[Modified by thumpu77, 5:22 PM 3/26/2002]
well if mine was in id take pics but its to damn heavy for my car to have in and im practically deaf now...
i had an Orion XTR 900 mounted on th edrivers side rear seat and a Orion XTR 500.4 mounted on the pass rear seat and a big *** Box with 2 Eclipse aluminum 12s like colins box up there..... pretty straight forward
http://members.sounddomain.com/cspu2
Here's my humble system... it sounds really good, but it won't win any SPL competitions.
There are lots of system ideas and plenty of Civics on that site too.
Lil Cs ZC, I like the idea behind the set up, looks clean.But i'm looking to keep my back seat, and my trunk space.I'm setting it up some thing like what Thump 77 said, but i'm not beating the bottom of my Del Sol seats to put in the Amps.I was looking to add an Amp rack similar to what CPSU has. But I want my Amps hidden.
Thinking of putting up a thin wall on the back side of the back seat.And mounting the Amps on the wall, between the wall and the seats.That way no one can see the system and I can let down the back seats to adjust the Amps and allow air to them when I'm cranking it up.
i had mine the same way the amp and my seats folded down fine i wouldnt recomend it if u dont have an amp with a fan cause its kinda upside down and can over heat
CSPU,Can you still let down the back seats?And how is the Amp rack attached ?
As far as overheating... it really depends on the amp. Mine barely gets warm even when I'm abusing it... an RF might overheat though (not a dis, a fact. RF's run hot)
holy ****, I didnt think anyone else in the world ran the older version JBL GTi's any more. I have a set of 12's I run for street bumping, and I have a set of Digital designs 9012's and a zapco 9.0 for comps
What does that thing hit????
Sweet
[Modified by cbrman, 1:30 AM 3/28/2002]
Sweet
ctownintegra
Audio / Security / Video
11
Feb 22, 2005 03:30 PM
Bodman
21
Nov 12, 2003 11:11 PM
99fbpem1
Jun 6, 2003 08:08 AM
quickLSt
16
Jul 22, 2001 02:20 PM
