brake lights wont work
so heres the problem...basically my brake lights wont work when i push the brake...ill put in a new bulb, itll work for maybe a week...and not work anymore..can someone please tell me whats wrong with my car...98 prelude
could be a fuse or it not grounding right and burn your bulb. check for loose wire and the fuse. i had the same problem with my reverse light and found out it was ground out.
Just for the record - the brake light fuse is under the hood - its called "small light"...........i had a hard time finding it ocne before.
Don't know why they named it that instead of brake lights.
Does your interior lights come on? If not, then its your fuse - but if they do come on(the heater controls) - then its something else.
b18c1vtecdc2
Sep 2, 2013 09:31 PM
