will type R rear seats fit in a 90 hatch
Old Mar 25, 2002 | 09:03 PM
1slowassr's Avatar
Default will type R rear seats fit in a 90 hatch
my question is will type R rear seats fit in a 1990 hatch cause i know that they will in the 92 and ups im about to buy one and want to know if they will fit
Old Mar 26, 2002 | 07:13 AM
eg6ajk's Avatar
Default Re: will type R rear seats fit in a 90 hatch (smoove466)
yes they will fit, just some modifications to the rails will be required (very simple) redrilling/enlarging the holes....
Old Mar 26, 2002 | 09:00 AM
Hayasa15's Avatar
Default Re: will type R rear seats fit in a 90 hatch (eg6ajk)
the rear seats have rails?
Old Mar 26, 2002 | 09:17 AM
bryant's Avatar
Your thinking of the front seats. As far as the Back R's fitting in the back of EF hatch, try it and find out.
Old Mar 26, 2002 | 10:25 AM
TypeR0207's Avatar
Default Re: will type R rear seats fit in a 90 hatch (CR-X)
Based on my experience of removing both, they LOOK like they should fit .... but that doesn't mean they will. They DO fit in '92-'95 Civics, so if the '92-'95 stuff fits in the EF's, then it should work.
Old Mar 26, 2002 | 01:28 PM
xJ.SLOTHx's Avatar
90' civic hatch's cant use any other seats unless you use harness's or something cuz the part that the seatbelt goes into is attached to the seat and not the floor of the car...
Old Mar 26, 2002 | 03:27 PM
chhuong's Avatar
Default Re: will type R rear seats fit in a 90 hatch (ian)
I don't know why everyone on here keeps talking about the front seats when you only asked about the rears. But to answer your question the upper folddown portions will fit without a problem, the bottom rear piece can be modded to fit but you will have like a 2 1/2 - 3 inch gap on each side which is ugly, but you can probably get a 90-91 si bottom piece that will basically match it in color and will look better.
Old Mar 26, 2002 | 03:48 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: will type R rear seats fit in a 90 hatch (chhuong)
i thought only the bottom cushions from a 4dr will fit in a hatch and since there aren't 4dr type Rs...
and ian: you're thinking of 88-91 sedans and 90-93 integras...no?
Old Mar 26, 2002 | 07:45 PM
xtrafastcivic's Avatar
Default Re: will type R rear seats fit in a 90 hatch (HoMoCo FoLife)
no 4 dr type r says who???
EGCIVICKING95
Sep 15, 2011 05:27 AM
projsectEF
May 15, 2006 05:00 PM
RICE POLICE SIP
10
Jul 25, 2003 01:07 AM
projecthybrid04
Mar 22, 2003 11:00 AM
EF'n Fast
Mar 18, 2002 11:07 PM
