Tranny Making noise..i think...*searched* please help
well i just swapped a b20z2 into my ej8*i know its the integra section* it has an LS tranny..i get this wierd noise from under the hood im almost positive its the tranny because if i put the clutch in the noise seems to nearly go away.
Its a noticeable noise and the tranny has had problems in the past (whining) im just wondering if its the engine or more likely the tranny...any help would be greatly appreciated.
Probably a bad bearing in the transmission, and who knows what else. Transmissions that have bad bearings area also likely to have other problems as well (popping out of gears, grinding, not going into gears, etc.).
A clutch release bearing might be a small possibility, but not likely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scribblyscraps »</TD></TR><TR><TD CLASS="quote">had the same problem in my b18a cr-x...never figured out what it was</TD></TR></TABLE>]
still have the problem? i dont think my tranny is gona last much longer lol...
Accord15
Jul 1, 2002 04:55 PM
