Differance between left and right side axles.
Old Feb 8, 2006 | 11:01 AM
Wayne_Curr's Avatar
Default Differance between left and right side axles.
Bought a pair today, they both have differant ends where they meet up with the tranny. Are they suppose to be differant in that way or did I get wrong parts...how do I tell which is which (other than comparing to the old axles i'm replacing) B Series engine.
Old Feb 8, 2006 | 11:23 AM
jlicrx's Avatar
Default Re: Differance between left and right side axles. (Wayne_Curr)
they are different - the splines on the driver's side axle are longer where it goes into the intermediate shaft - not the end, but the splines themselves
Old Feb 8, 2006 | 11:51 AM
Wayne_Curr's Avatar
Default Re: Differance between left and right side axles. (jlicrx)
is the driver side suppose to be female where it meets up with the intermediate shaft? Thing is one axle has female end one has male end.
Old Feb 8, 2006 | 12:02 PM
EP3_05's Avatar
Depends on your intermediate shaft. The 90-93 integra axles which most people use for b series swaps into the 88-91 civic/crx are both male ended. I believe the newer intermediate shafts require an axle with a female end.
Old Feb 8, 2006 | 12:12 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">is the driver side suppose to be female where it meets up with the intermediate shaft? Thing is one axle has female end one has male end.</TD></TR></TABLE>
you have GSR axles
Old Feb 8, 2006 | 12:18 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">you have GSR axles</TD></TR></TABLE>
This is a B18b, i take it the axles are differant from B18c?
Old Feb 8, 2006 | 03:05 PM
crxtreme89h's Avatar
If you have an intermediate shaft with 2 male ends then you need 94-01 Integra Axles. If you have an intermediate shaft with 1 male and 1 female end then you need 90-93 Integra Axles.
oneslodx
May 26, 2004 11:57 PM
Bob_Digi
Feb 23, 2004 03:17 PM
sabertooth
Jan 21, 2004 06:27 PM
McDade
Sep 1, 2003 07:49 AM
