can you use an OBD0 LS dizzy for an MPFI swap?
Old Feb 8, 2006 | 08:08 AM
thenick's Avatar
Default can you use an OBD0 LS dizzy for an MPFI swap?
I searched and couldn't come up with an answer
Old Feb 8, 2006 | 08:55 AM
EF_9's Avatar
Default Re: can you use an OBD0 LS dizzy for an MPFI swap? (thenick)
you can if your going to swap a 90-91 LS in
Old Feb 8, 2006 | 09:50 AM
Rywire's Avatar
Default Re: can you use an OBD0 LS dizzy for an MPFI swap? (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">you can if your going to swap a 90-91 LS in</TD></TR></TABLE>
If you are trying to get that ls dizzy to fit a a6 eng, then good luck getting the timing correct... You may get it, but you are gunna have to hack off legs to make it work
Ryan
Old Feb 8, 2006 | 10:00 AM
thenick's Avatar
Default Re: can you use an OBD0 LS dizzy for an MPFI swap? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">
Ryan </TD></TR></TABLE>
thank you
Huntley2147
55
Jun 23, 2007 01:30 PM
Hazymix
12
Aug 23, 2006 09:01 PM
DualCamDan
10
Feb 4, 2006 05:12 AM
==Catfish==
Mar 24, 2005 11:08 AM
crxgsr91
Nov 15, 2004 04:30 AM
