code 8 tdc need help asap!!!!!!
Old Feb 8, 2006 | 05:35 AM
bbrian's Avatar
Default code 8 tdc need help asap!!!!!!
my car was throwina code 8 which i think is the tdc ,, would that make the car idle weird and run funny ..thanks
Old Feb 8, 2006 | 05:40 AM
crx_88_si's Avatar
1. first things first. Always reset the ECU and make sure the code comes back to insure a problem that is not intermitant.(sp)
2. replace dist rev limit is 3,000rpm right?
Old Feb 8, 2006 | 08:40 AM
ZChatch90's Avatar
Default Re: code 8 tdc need help asap!!!!!! (bbrian)
is this the origional motor or a swap cuz i had that prob with a b18 swap and it was bad wiring but if u mean running funny like when u are at 3,000 and it feels like it is killing fuel then turning back on, well that means u have a bad wiring job if it is a swap use a digital multimeter to check for resistance.
Old Feb 8, 2006 | 04:32 PM
bbrian's Avatar
bump yea me and my friedn just swapped a 92 teg motor in my 91 dx hatch and it will idle fine for a min then drop down but then will shoot back up i have no idea what it could be
Nathan_volcom
Dec 4, 2011 03:01 PM
ekb16a
Aug 4, 2007 08:29 PM
mike84 CRX-GTL
12
Sep 12, 2005 03:44 PM
Bright Eyes
Jun 3, 2005 05:52 PM
Red_Si
21
Jan 9, 2004 04:53 AM
