Type-R running too cool?
Old Feb 7, 2006 | 09:16 PM
sirrjibbalott's Avatar
Default type r temp
right below the middle line is ok
Modified by sirrjibbalott at 1:09 PM 10/14/2006
Old Feb 7, 2006 | 09:35 PM
iBear's Avatar
Default Re: Type-R running too cool? (sirrjibbalott)
I don't have a Type R motor, but my LS or any other Honda/Acura I've been in the needle is usually below the middle. I think you're fine.
Old Feb 7, 2006 | 11:04 PM
Reid's Avatar
Global Moderator
It's completely normal.
Old Feb 7, 2006 | 11:36 PM
ans's Avatar
ans
Mine usually stays at 1/2 to mid temp, don't think it has ever touched the middle line
Old Feb 8, 2006 | 02:18 AM
benjamin's Avatar
Default Re: Type-R running too cool? (ans)
if you are real worried or it gets worse just get a new thermostat there like 12 dollars and take 15 min to install
Old Feb 8, 2006 | 02:25 AM
Reid's Avatar
Global Moderator
Default Re: Type-R running too cool? (benjamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benjamin &raquo;</TD></TR><TR><TD CLASS="quote">if you are real worried or it gets worse just get a new thermostat there like 12 dollars and take 15 min to install</TD></TR></TABLE>
Why are you suggesting that he change parts when there is nothing wrong?
Old Feb 8, 2006 | 04:57 AM
Larkin W.'s Avatar
Default Re: Type-R running too cool? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">It's completely normal. </TD></TR></TABLE>
Agreed, you temperatures Sound normal to me.
You will know when you are running too Cool. Temp guage will only get to first tick mark or 1/8th across the temp guage and you most likely will throw a CEL because the secondary (heated) 02 sensor isn't getting hot enough.
Old Feb 8, 2006 | 05:12 AM
KetteringITR's Avatar
Default Re: Type-R running too cool? (Larkin W.)
Running cold is never making it to the first hash line on the temperature gauge. Thats what my R did and i replaced the thermostat and now im back to normal (about 3/4 the way to the middle line). I think ure fine.
Old Feb 8, 2006 | 05:50 AM
Default Re: Type-R running too cool? (KetteringITR)
thanks guys you were alot of help
For everyone on Honda-Tech
Old Feb 8, 2006 | 05:58 AM
migs's Avatar
My turbo R sits at the line below midway
My all motor gsR sits just a hair beneath halfway. It also has a larger radiator.
Whats the deal?
Old Feb 8, 2006 | 12:00 PM
type_r_jon's Avatar
drive it harder and shift higher if that doesn't work take some coolent out, if you see smoke you took too much out.
Old Feb 8, 2006 | 12:52 PM
B7AudiA4's Avatar
get a new guage? =P
It's not running cooler...
My friend's EG swap was doing the samething until he changed to an integra guage
Old Feb 8, 2006 | 04:57 PM
AntiStock's Avatar
Default Re: Type-R running too cool? (FutureITR)
lol...with the Spoon thermostat, C&R full length radiator and SPAL fan my needle never goes far enough to uncover the "C" line (shows ~120* F on the AutoMeter gauge) while cruising.
ToeJam
Jul 13, 2007 06:15 AM
Declectic
Honda Civic (2006 - 2015)
Jul 22, 2006 11:23 PM
bamateg94
Apr 19, 2006 05:36 AM
FakeJDMEF8
Sep 14, 2005 08:01 PM
Honda4CX-T
16
Feb 15, 2002 06:02 PM
