Just bought a new head, have questions.
The following are some pics of the 98 LS head i recently purchased.
For the most part i just want to know if anything looks bad/wrong/not in the right place.
Also i got quoted on a PnP/3 angle valve job, for this head for 700 bucks. Does that sound about right ?
This head has about 100,000 miles on it, i already know i need a valve cover gasket since there isnt one at all.
Thanks in Advance.
Thanks in Advance.
He said 700 for the p&p job, not cost of buying it.
Looks pretty good, not sure about the cost for a p&p,
even though that does seem steep for the type of gains.
yeah youre right, i misread that, but for 700 you can still get a gsr head..that was my point pretty much..unless you want no vtec for whatever reason
well i have a LS and this will be part of my LS-Turbo build, and i only paid 60 bucks for this head.
One more question is whats the best way to store this head while im waiting for head bolts, crower valvetrain, cams ect ect.. Right now its in a box with bubble wrap all over it.
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">also how should i store this while im waiting on parts ?
woot 1000 post
my friend just wrapped the head in plastic wrap until he built his motor...make sure its coated in wd40 before you wrap it...
thats what id do
woot 1000 post
</TD></TR></TABLE>my friend just wrapped the head in plastic wrap until he built his motor...make sure its coated in wd40 before you wrap it...
thats what id do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">how much did you pay for it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote"> and i only paid 60 bucks for this head. </TD></TR></TABLE>
Also, I agree on soaking it with wd then wrapping it, it'd be a good choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg »</TD></TR><TR><TD CLASS="quote">
Also, I agree on soaking it with wd then wrapping it, it'd be a good choice.</TD></TR></TABLE>
damn, thats cheap.
damn, thats cheap.
i would send it to a machine shop and get it checked out first. pressure test it and leak test it, see if it needs any work before you put it aside becuase you don't want to go to install it and find out you have a problem. better safe then sorry
thanks for all the replies
the first thing thats gonna be done is the pnp/valve job, after that it will be stored away for a couple of months. Do you guys recommend any shops that i can send to in CA/NV/AZ ?
i have a question...finally the opportunity comes up...can someone edit the pic of the head with the valve cover off and show me exactly where to put the feeler gauge when doin a valve adjustment....like cirlce it with blue and put an arrow on which side to put it in at...id appreciate it much...ive been tryin to get my valve to stop clickin and ive had no luck
ive noticed cylinder #1 is at tdc..so if u could explain on that cylinder....
thanks so much to whoever is willing to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">woot 1000 post
and if you value them, i wouldnt do that again.. just giving you heads up
on a brighter note.. keep us posted on the build up of this mang.. its always nice to see pictures of other peoples build up.. and it helps me learn in a way as well
</TD></TR></TABLE>and if you value them, i wouldnt do that again.. just giving you heads up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">and if you value them, i wouldnt do that again.. just giving you heads up</TD></TR></TABLE>
It was used as a TTT or bump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O5GOAT »</TD></TR><TR><TD CLASS="quote">He went LS because he couldn't handle hitting 3rd gear VTAKKKKKK!!!!!!!!!</TD></TR></TABLE>
I guess you now know what i bought
Bro help me find a good shop in CA/NV/AZ that i can send my head to get worked on
thanks.
Also i was told to stand my whole cylinder head vertical, i know this applies to a crankshaft but does it matter to a head ?
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">Bro help me find a good shop in CA/NV/AZ that i can send my head to get worked on
thanks.
Ask in the all motor forum</TD></TR></TABLE>
thanks.
It was used as a TTT or bump.</TD></TR></TABLE>
i know but i've seen to many times people refering to their post count and get that **** reset to 0..
but i dont wanna get off topic like i already am
plonger
10
Mar 10, 2003 12:46 PM
