shift linkage
Old Feb 7, 2006 | 08:10 PM
SupraRXZ's Avatar
Default shift linkage
Does anyone know the measurements if i have a stock LS shift linkage, how much i would have to cut and weld it to put it on my Ef with a bseries engine?
Old Feb 7, 2006 | 10:22 PM
SupraRXZ's Avatar
Default Re: shift linkage (SupraRXZ)
bump
Old Feb 7, 2006 | 10:28 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the measurements if i have a stock LS shift linkage, how much i would have to cut and weld it to put it on my Ef with a bseries engine?</TD></TR></TABLE>
I have seen alot of people not weld it off center and the shifting is just never as smooth as it is with the correct linkage. $125.00 new but if you HAVE to weld it just make sure it's as close to possible back to it's original line.. The distance??? sorry I don't have that one because my REX came with the Hasport linkage already.
Old Feb 8, 2006 | 05:39 AM
Black4thgenEF's Avatar
Default Re: shift linkage (VtecSyndrome)
I think I had to take about 2 1/4" off my gsr linkage. Measure for yourself just to be sure though. If you cut it out of a straight section you shouldn't have a problem. Mine shifts great.
Old Feb 8, 2006 | 05:57 AM
HondaFerris's Avatar
Default Re: shift linkage (Black4thgenEF)
Ive seen some people cut out a short piece, then weld a nut and bolt on so its adjustable...not too familiar with custom linkage though so you'd have to search around...
edit: i did a search and came up with over 100 topics...also this page may help... http://www.performanceforum.co....html
shortstopNE
Aug 12, 2012 04:30 PM
moskaEF9
Sep 26, 2009 08:19 AM
CRX_RR
Mar 26, 2008 10:11 PM
tealjdmcrx
Welding / Fabrication
Feb 21, 2006 10:41 AM
