FS: Autronic SMC v1.92 with B harness
Old Feb 7, 2006 | 06:39 PM
AutoLab's Avatar
Default FS: Autronic SMC v1.92 with B harness
Selling my Autronic SMC v1.92 ecu with all required sensors and harness.
included sensors are the autronic intake temp sensor and coolant temp sensor. the ecu has an internal Map sensor, just simply run a vacuum line to the ecu and youre done. Use stock TPS sensor, only thing left to do is wire in your own ignition box, right now we're using a MSD DIS4 so if you have one of these your install would be cake.
The harness has been fitted to a B series engine in our race car and the car ran great. This harness will not be 100% plug and play you will have to do some work on your own such as power, grounds, wiring in your ignition system etc but it is a great step in the right direction which will save you time and money. We have the original SMC instruction manual that you will get as well.
We are simply changing to a larger scale ECU that has 3 dimensional boost mapping, other than that we have no complaints with the SMC model ecu from Autronic. But for the price you cant beat it.
New theyre $1895, we get around $450-550 to wire them in. In an hour or two you could wrap up the last of the wiring to your specific application and have Autronic power, control and most importantly reliability. I need $1450+s&h firm.
-bill
bill@autolabonline.com
(502)266-6646
AIM: ForcedSol
Modified by AutoLab at 7:52 PM 2/7/2006
Old Feb 9, 2006 | 03:21 PM
AutoLab's Avatar
Default Re: FS: Autronic SMC v1.92 with B harness (AutoLab)
PMs returned
Old Feb 11, 2006 | 03:03 PM
wade's Avatar
BUMP
Old Feb 13, 2006 | 12:25 PM
wade's Avatar
Default Re: FS: Autronic SMC v1.92 with B harness (wade)
his is an outstanding EMS especially for people wanting to make big power! BUMP
boostedblue23
Apr 6, 2018 06:53 AM
Too_slow_eg
Mar 23, 2011 08:58 AM
Too_slow_eg
Feb 25, 2011 05:19 PM
JDMInspired
Honda Civic (2001 - 2005)
Mar 10, 2008 06:30 PM
rpm9100
May 11, 2003 08:55 PM
