COMPRESSION CRX HELP!
Old Feb 7, 2006 | 05:52 PM
tatted91rex's Avatar
Default COMPRESSION CRX HELP!
iight soo this is how it goes i checked the compression on my crx with b16 and 3 cylinders are at 200 lbs and one cylinder is at 175 do you think the rings are going any help anyone?
Old Feb 7, 2006 | 05:59 PM
si0385.'s Avatar
Default Re: COMPRESSION CRX HELP! (tatted91rex)
iight any cylinder thats more than 20 psi different than the other three is somethingn to worry about that means something is going bad...
it could be a number of things but you shoulds get it checked out because if you got 200 in 3 and 175 in another thats too low....
in the cylinder that only had 175 how many times did you crank it... did you put some oil in the cyl to see if the compression goes up (thats how you check if its a ring to answer your origional question)
you can also use a vaccum guage to see if its a bent valve if the oil in the cyl does not bump the compression...
are you using any forced induction or nitrous???
Old Feb 7, 2006 | 06:36 PM
Default Re: COMPRESSION CRX HELP! (jaydeum4lyfe)
no nitrous or turbo and i cranked it 5 times on each cylinder btw the b16 is stock and i was using a no rev limited ecu at the time and i over revved it on a missed shift prob brought it up to about 11 its been shutting off on me lately during driving like when i come to dead stops
Old Feb 7, 2006 | 06:41 PM
si0385.'s Avatar
thats why im against ecu's with no rev limit... if you are gona do that at least have some other sort of ignition cut off for a govenor EXPECIALY on a stock motor there is no reason to have no revlimit... its insurance that woulda helped you out alot for less money than rebuilding a b16
you could have done so many things if you reved it that high, does it smoke or is there oil in the antifreeze???
Old Feb 7, 2006 | 06:44 PM
Pee Wee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatted91rex &raquo;</TD></TR><TR><TD CLASS="quote">no nitrous or turbo and i cranked it 5 times on each cylinder btw the b16 is stock and i was using a no rev limited ecu at the time and i over revved it on a missed shift prob brought it up to about 11 its been shutting off on me lately during driving like when i come to dead stops</TD></TR></TABLE>
i guess you learned the hard way
Old Feb 7, 2006 | 11:11 PM
Default Re: COMPRESSION CRX HELP! (Pee Wee)
i didnt blow the headgasket or nothing like that cuz theres antifreeze in the oil i dont hear nothing hitting nothing i dunno man ***** been pissing me off though but do you think that 25 lbs in difference in the compression could be why the motor will shut off on me sometimes?
stir_fry_boy
May 15, 2018 06:27 AM
zc89hatch
13
Dec 21, 2008 11:40 AM
cxVtecC1
Feb 18, 2005 06:54 AM
greenli0n25
Jan 26, 2004 07:29 AM
