DOT 3 Vs. DOT 4 Brake Fluid
Old Feb 7, 2006 | 05:19 PM
ys1civic's Avatar
Default DOT 3 Vs. DOT 4 Brake Fluid
Just wondering did the integra rear brake conversion and heard some here say on fluids. Just wondering if a DOT 4 fluid will make the car stop harder and brake faster then a DOT 3 fluid? Running all stock components stock SI front brakes with all stock SI Brake lines and 90' LS rear brakes with a 90' 40/40 prop valve. Will it make a difference running a DOT 4 over a DOT 3 fluid?
THANKS
Old Feb 7, 2006 | 05:57 PM
ludesrv's Avatar
Basically the same fluid. I beleive the Dot 4 withstands to higher heat and doesn't compress as much, so it makes the pedal stiffer.
Old Feb 7, 2006 | 07:08 PM
Crx Jimmy's Avatar
Default Re: DOT 3 Vs. DOT 4 Brake Fluid (ys1civic)
dot 4 just has a higher boiling point, unless you are driving on a track or towing something you wont know the difference
Old Feb 7, 2006 | 07:41 PM
blah13's Avatar
Default Re: DOT 3 Vs. DOT 4 Brake Fluid (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">dot 4 just has a higher boiling point, unless you are driving on a track or towing something you wont know the difference</TD></TR></TABLE>
x2
DC4R27
Dec 2, 2009 10:03 AM
Flux
May 24, 2005 12:03 PM
blkgsr03
Apr 16, 2004 09:21 AM
TheOne
Jul 20, 2003 03:28 PM
ssbgsr
Apr 30, 2003 04:13 PM
