87 honda accord
Old Feb 7, 2006 | 03:49 PM
gunner1551's Avatar
Default 87 honda accord
hi i just bought a 87 accord that was in storage for a while, hence the owners manual has gone missing. i was tryin to find out what tpye of engine it had in it. can somebody give me some addvice on where to look for the engine number?
Old Feb 7, 2006 | 04:26 PM
P_Adams's Avatar
Default Re: 87 honda accord (gunner1551)
United States Market
'87 -'89 DX/LX (USDM)
A20A1 code 1955cc, 95hp @ 5500rpm / 109ft/lb Torque ( 2bbl Carb )
'87 LXi (USDM)
A20A3 code 1955cc, 110hp @ 5500rpm, 114ft-lbs Torque ( PGM-FI )
Canadian Market
'87 EX (EDM)
A20A2 code
'87 EXi (EDM)
A20A4
To verify what you have, there should be a machined pad on the Engine Block where the trans mounts; which will have the engine designator stamped.
P
Old Feb 7, 2006 | 09:21 PM
gunner1551's Avatar
Default Re: 87 honda accord (P_Adams)
thanks for the quick reply and the information. so are those the only two engine types it could be?? in reference to what you said about the canadian/us markets, when i looked up the serial number it said it was manufactured in japan.
Old Feb 8, 2006 | 04:55 AM
P_Adams's Avatar
'87 was right about when Honda started manufacturing accords off-shore (other than Japan), but there were still quite a few still making the boat trip.
What badge (emblem) sits on the rear panel? EX, EXi, DX ?
First Digit of your Vin designates Country of Origin:
1 = USA
2 = Canada
3 = Mexico
4 = USA
J = Japan
K = Korea
V = France
Old Feb 8, 2006 | 06:34 AM
gunner1551's Avatar
The first digit did verify that it was manufactured in Japan. The emblem on the rear of the car is EXi, what does that tell you??
Old Feb 8, 2006 | 09:00 AM
P_Adams's Avatar
A20A4 EXi (EDM (European Domestic Market)
1955cc (2.0L) SOHC 12 Valve (2 Intake, 1 Exhaust) 122hp @5500rpm / 166n/m Torque
PGM-FI Fuel Injection
The EXi is the canadian version of the USDM LXi
P
Old Feb 8, 2006 | 11:04 AM
gunner1551's Avatar
so you are sure that, thats the motor that is in there?? man you have a vast knowledge of honda!! thanks alot man. oh and another thing where could i pick up an owners manual?
Old Feb 8, 2006 | 11:11 AM
TouringAccord's Avatar
H-T Order of Merit
yes, P is a very smart person he knows his stuff
You can probably find an owner manual in good shape on eBay for a decent price.
Old Feb 8, 2006 | 03:57 PM
gunner1551's Avatar
Default Re: 87 honda accord (TouringAccord)
well i went and had a look at the block and i cant find the face plate. will have another look, but I did find a plate on the hood, it didnt really have any info that i didnt already know except one thing did puzzle me. I said under engine type C87E. does that meen anythin to anyone?
oh and ps with the trial membership of the forum why are you restricted to only 5 posts a day. i was pissed off when i went to post and i read that.
Old Feb 8, 2006 | 06:19 PM
P_Adams's Avatar
It's not a "Plate" as such. It's no more than a flat machined surface (as opposed to a cast surface) and some poor flunky has the job at the engine assembly plant of standing there stamping blocks. (for $24./an hour USD or $27.69 Canadian )
The C87E designator doesn't come up on anything I can reference, but rest assured, if it's the original engine - it's the A20A4
P
Old Feb 9, 2006 | 05:01 AM
Tim B's Avatar
hey P can you tell me the specs of the motor thats in a 1991 honda accord EX The 1st Number on the Vin is a 1 so itwas made in the USA from what you have posted all ready.
Old Feb 9, 2006 | 05:04 AM
H-T Order of Merit
Default Re: (Tim B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim B &raquo;</TD></TR><TR><TD CLASS="quote">can you tell me the specs of the motor thats in a 1991 honda accord EX </TD></TR></TABLE>
F22A6, click the link below for the specs
http://www.accordinglydone.com...ies=F
Old Feb 9, 2006 | 05:19 AM
P_Adams's Avatar
Default Re: (Tim B)
I believe it's the F22A6. Available in the 1991 thru 1993 EX Accords
Specs:
2156cc 16 Valve SOHC Non-Vtec
8.8:1 Compression ratio
140HP @5600 RPM
142 ft-lbs Torque
P
Old Feb 10, 2006 | 10:28 PM
gunner1551's Avatar
Default Re: (P_Adams)
thanks alot for the help P_Adams.
Old Feb 12, 2006 | 05:46 PM
jdmb20a's Avatar
Default Re: (gunner1551)
for lots of info about the 87, check out http://www.3geez.com
great board for 86-89 accords.
Old Feb 12, 2006 | 06:25 PM
P_Adams's Avatar
Default Re: (jdmb20a)
Although most of us here aren't slouches either.
Actually you're quite lucky; most other forums would edit out you're reference to that other site - and lock out your ip address
P
lgharis
Oct 12, 2007 11:08 PM
95civiccpdx
Jun 28, 2007 03:43 PM
62maxx
Oct 14, 2006 02:53 PM
91 HONDAsaurus rex
Sep 28, 2004 03:40 PM
ITls1995
May 3, 2004 11:54 PM
