Vortech Supercharger 04 S2000 Polished kit
$4600.00
The Vortech High Output Supercharging System will add 118 horsepower @ 7-8 psig to the S-2000. It features a V-2 SQ SC-Trim supercharger and allows retention of all factory accessories including A/C and power steering. The integrated dual pass air/water Maxflow Power Cooler charge cooler system allows for effective street operation using a closed loop water cooling system with a stand-alone pump, tank and front mounted heat exchanger. All components needed to bolt the system to a stock vehicle, such as mounting plates, fuel pump, supercharger oil feed and drain assemblies, electronic timing controller and compressor bypass valve are included. This system is 50-state smog legal under CARB EO #D-213-23.
$4600.00
justahatch09
Oct 16, 2014 07:52 PM
vinmotors
Apr 5, 2013 03:59 PM
RiceRocketRoni
Honda S2000
Jun 28, 2002 10:54 AM
