passeger headlight problem
Old Feb 7, 2006 | 03:08 PM
korney's Avatar
Default passeger headlight problem
don't worry I have searched, ok well the other day I notice while driving home from work at night, my passeger and the driver side's high beams are half way on. The passeger low beam and half way on too but the driver side's low beam is on and the high beam is on half way. Is there a wireing problem or something? help please thanks,...
Old Feb 7, 2006 | 03:10 PM
korney's Avatar
Default Re: passeger headlight problem (korney)
oh yeah and when I try to put on the high beams, only the driver side high beam goes on and the passenger side headlight is totally off....
Old Feb 7, 2006 | 04:41 PM
VtecFreePrelude's Avatar
what?
do you have any pictures of this cause i'm confused.
Old Feb 7, 2006 | 06:38 PM
M2B4's Avatar
ok very confusing. 1st off did u install jdm headlights or are they oem? if you installed jdm ones it sounds like you connected some wires wrong. if there oem i would check the bulbs and make sure there all good and check the wires for cuts only advice i can give for now your issue was very confusing.
Old Feb 7, 2006 | 07:27 PM
Audiotek's Avatar
Hi all, First post....
If your lighting is all still factory, your problem may be in the factory alarm harness area. This happened to me last week while installing my aftermarket alarm. There is a 4 pin brown relay plug/harness under the drivers side dash, above the fuse box. This plug would hold a relay that flashes your headlights when your factory alarm is set off. The wiring will be there even if you do not have a factory alarm. I had clipped a wire from this harness and never connected it back up. Dont quote me on this but i think it was a red/yellow wire. Anyway, had the same EXACT problem as you. Connected the wire back up the next day and all was well. If everything seems ok under the dash, take a look at the under hood fuse box. Make sure your "lighting" relay is OK
Hope this helps -Joe
Old Feb 8, 2006 | 07:29 AM
so one wire not being connected is causing that mess?
doesn't seem right...
Old Feb 8, 2006 | 06:00 PM
Audiotek's Avatar
yep, there is actually two of these red/yellow wires both going to the same terminal on the relay plug. They are Joined together there. I was suprised it was that easy of a fix. I lost some sleep over it because I thought it would be a huge wiring issue like possable melting/overheating. Same EXACT symptoms. The problem was hard to notice at first because of the one headlight/highbeam being HALF way on. When I turned my brights on, the low and high beam completely went out. Best of luck Korney, post back on how it went, maybe some more details could steer us in the right direction
Modified by Audiotek at 9:23 AM 2/9/2006
hotaccord243
May 29, 2008 01:00 PM
Will_H
Sep 8, 2007 05:19 AM
Preferio
Apr 11, 2007 09:38 AM
just4747
Oct 11, 2004 06:56 AM
redEH2
Feb 2, 2004 01:34 PM
