Euro-R Throttle Body/IM vacuum lines...*Pics*
Old Feb 7, 2006 | 02:50 PM
snowblind7x's Avatar
Default Euro-R Throttle Body/IM vacuum lines...*Pics*
I got a Euro-R H22 put into my prelude and the guy did some ghetto stuff with the vacuum lines. There were a few nipples with no lines attached to them at all and one line had a screw in it to block it off....Anyway, i'm trying to figure out where all these lines should go so any help is appreciated.
First of all, is this even a Euro-R throttle body? If you can tell from these markings...
are these lines going in the right places?
Where should this be connected to?
And this is the line that just had a screw stuck in it to plug it up and the nipple on the back of the IM wasn't connected to anything. Is this right?
After connecting all the hoses as shown my car idles a lot better than it did when i first got it back. It was very low and lumpy before and now it idles a lot smoother but really high at about 1500 rpms. The high idle could very well possibly be because of whatever massive vacuum leak i have. I hear a constant MASSIVE vaccum leak. I'm taking it back to him soon for him to fix the vacuum leak and im hoping that will lower the idle.
Modified by snowblind7x at 4:51 PM 2/9/2006
Modified by snowblind7x at 4:53 PM 2/9/2006
Old Feb 7, 2006 | 04:03 PM
SteveoBA8's Avatar
Default Re: Euro-R Throttle Body/IM vacuum lines...*Pics* (snowblind7x)
Try the Faq's, there is a vacuum digram in there. The one under your tb is for a coolant hose. Have your mechanic do a vacuum test on your engine, should be getting 18-22 hg's at idle.
Old Feb 7, 2006 | 04:59 PM
98Luder's Avatar
The EuroR TB has no idle screw so that is a hint if you do or do not have a real EuroR TB.
Also, if i recall right the ID of the tb was 66mm on the EuroR TB
that center vacuum line the big one, i think goes to your EVAP canister
that bottom rusty connector is your fast idle control, there should be 2 lines, one in one out, one goes into IAC, theother to your thermostat housing
is your idle pretty messed up?
hey someone had this on another thread in the Prelude forum
Old Feb 7, 2006 | 06:36 PM
v4lu3s's Avatar
RTFM
are there drivability problems?
Old Feb 7, 2006 | 07:43 PM
Fly1865's Avatar
Default Re: (v4lu3s)
If thats a Euro R manifold where is the IACV? It should be on the back right next to the TB. Your doesn't seem to have it there. Could you take more pics of the whole manifold?
Old Feb 7, 2006 | 08:41 PM
CompanyFlow's Avatar
Take it back to his *** and tell him to fix it.
Old Feb 7, 2006 | 09:52 PM
Default Re: Euro-R Throttle Body/IM vacuum lines...*Pics* (CompanyFlow)
There are no drivability problems. It runs really good, just the vacuum problems/leaks. The Idle is fine except it idles at 1500 but that is probably because of whatever vacuum leak I have. And to the question about the IAC....wtf...I didn't even notice that. There is a plate blocking off where the IAC should be on the back. You can see it if you look closely at the 4th pic. Any info on that would be appreciated as well. I didn't know you could just delete the IAC...
Old Feb 7, 2006 | 10:02 PM
TOP END MS's Avatar
That adapter plate is required and they should have drilled two holes in the center of it for the ports.
Old Feb 7, 2006 | 10:08 PM
Default Re: (TOP END MS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS &raquo;</TD></TR><TR><TD CLASS="quote">That adapter plate is required and they should have drilled two holes in the center of it for the ports.</TD></TR></TABLE>
Yeah, but they didn't, and there is just no IAC at all. What are the negative affects of not having an IAC? Just a funny idle or what? Either way, i'm gonna get the IAC put on the right way...
Modified by snowblind7x at 11:30 PM 2/7/2006
Old Feb 8, 2006 | 11:18 AM
Fly1865's Avatar
Default Re: (snowblind7x)
Well since you don't have a IACV thats why it idles at 1500, put it where it is suppose to go and see if that doesn't correct your problem.
Old Feb 8, 2006 | 11:26 AM
PreLuDeSiR's Avatar
Default Re: (Fly1865)
its looks like the guy you got it from did the coolant bypass mod...
Old Feb 8, 2006 | 11:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fly1865 &raquo;</TD></TR><TR><TD CLASS="quote">Well since you don't have a IACV thats why it idles at 1500, put it where it is suppose to go and see if that doesn't correct your problem.</TD></TR></TABLE>
Yeah, im gonna. But it seems to me that the idle would probably drop to where its supposed to be once i fix the vacuum leak. I hear a constant, loud "SHHHHHHH" coming from maybe somewhere under the intake manifold or something. Anyway, it's loud enough that it sounds like a pretty big leak and would probly lower the idle when i fix that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreLuDeSiR &raquo;</TD></TR><TR><TD CLASS="quote">its looks like the guy you got it from did the coolant bypass mod...</TD></TR></TABLE>
coolant bypass mod? What's that and what does it do?
Old Feb 8, 2006 | 02:15 PM
98Luder's Avatar
there is a vacuum line on the euroR intake manifold coming from under the right (passenger side) side that is suppose to connect to the IAC. If you put your hand under there you should feel it, just look at where the thermostat housing is and move your hand over towards the drivers side and you should feel the vaccum connector sticking out. It'll either be just bare or else you'll feel a vacuum line attached to it connected to nothing, not sure if he plugged it off during your swap or what? cause it is suppose to be attached to the IAC, not sure what' it's attached to now? nothing? maybe a bolt or screw plugging it? check it out let us know how it goes
Old Feb 9, 2006 | 03:54 PM
Default Re: (98Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Luder &raquo;</TD></TR><TR><TD CLASS="quote">there is a vacuum line on the euroR intake manifold coming from under the right (passenger side) side that is suppose to connect to the IAC. If you put your hand under there you should feel it, just look at where the thermostat housing is and move your hand over towards the drivers side and you should feel the vaccum connector sticking out. It'll either be just bare or else you'll feel a vacuum line attached to it connected to nothing, not sure if he plugged it off during your swap or what? cause it is suppose to be attached to the IAC, not sure what' it's attached to now? nothing? maybe a bolt or screw plugging it? check it out let us know how it goes </TD></TR></TABLE>
I couldn't find a nipple on the back of the intake manifold other than the one that is connected in the last pic. The only nipple i found was on the back side bottom of the throttle body...
Old Feb 10, 2006 | 12:39 PM
bump
Old Feb 11, 2006 | 06:41 PM
I found out that the throttle body isn't a Euro-R one. I dunno what it is though, all i know is it's way to small for my Euro-R IM. Now i need a new throttle body...
Old Feb 27, 2006 | 07:03 PM
TOP END MS's Avatar
Cant you just bore it?
Old Feb 28, 2006 | 09:00 PM
ejprimo's Avatar
the euro-r throttle body doesnt have an idle screw. my buddy has one for sale.
Old Feb 28, 2006 | 09:10 PM
YEABOY's Avatar
Default Re: (ejprimo)
Isnt the IAC in the front of the IM on the H22?
Old Feb 28, 2006 | 11:02 PM
redtop22's Avatar
Default Re: (Integ4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integ4Life &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the IAC in the front of the IM on the H22?</TD></TR></TABLE>
yes the IAC is on the front of a stock usdm intake manifold. the IAC on the EuroR intake however is located on the back of the manifold, next to the TB.
Old Jul 21, 2013 | 11:41 AM
damiun's Avatar
I have a problem with those same nipples at the back of the throttle body...have no clue where it goes,i had them both plugged and it idle great but when I drive like around 60 to 80km I get a hold back,but when I remove them and leave open I get good power but idea is very poor..it idle up then down,up then down like a breathing motion..i needhelp on this soon as I can..
jands
Jun 13, 2008 08:37 PM
prelude9999
Oct 8, 2004 10:01 AM
ARACER25
Oct 13, 2002 10:41 AM
