::Need reviews:: clutch master cylinder. OEM vs OMNI power
Old Feb 7, 2006 | 11:45 AM
.water's Avatar
Default ::Need reviews:: clutch master cylinder. OEM vs OMNI power
i need replcae clutch master cylinder soon. my queation is should i get OEM honda stock replacement one? or OMNI ones?? i read some reviews. people who have omni cylinder hows it? and does it looks like its gonna blow soon after having few months??
thanks for looking
Old Feb 7, 2006 | 12:26 PM
R-81DC2's Avatar
Default Re: ::Need reviews:: clutch master cylinder. OEM vs OMNI power (KaNg)
bump cause i wanna know to- always see it advertised for some crazy price
Old Feb 7, 2006 | 01:19 PM
vtakvtrak's Avatar
go with oem i did, its cheap too, buy it from hondaautomotiveparts.com
Old Feb 7, 2006 | 02:44 PM
Mt3c's Avatar
25 Year Member
there are several post in the EG/EK forum, even from users with b-series engines.
from what i understand, clutch engagement distance is much shorter, and force required is higher.
but if any teg owners have one, let hear from them.
Old Feb 7, 2006 | 03:20 PM
.water's Avatar
Default Re: ::Need reviews:: clutch master cylinder. OEM vs OMNI power (Mt3c)
well, ya i read that too. but there will be no harm in any tranny parts right??
Old Feb 7, 2006 | 05:47 PM
Mt3c's Avatar
25 Year Member
you are pushing the Slave cylinder the same distance, so i don't understand how there will be any tranny damage.
Omni - bigger cylinder, shorther distance displace same amount of fluid as stock cylinder with smaller cylinder, longer distance.
Old Feb 8, 2006 | 07:44 AM
ImportAutoPerformance.com's Avatar
Here you go: https://honda-tech.com/zerothread?id=1255302
Old Feb 8, 2006 | 04:25 PM
.water's Avatar
i see...after install do i need to adjust those sensors?? since cluch pedal is moved short. and there is still free play?? cause i heard w/o freeplay it gives pressure to the tranny parts. (clutch parts)
Old Feb 9, 2006 | 06:45 PM
muasboi's Avatar
i just bought mine from IAP..thank you!! anyways install for me was 1-10, then being the hardest..i'd have to say 5..just because of the akward position your in, when your under your dash..
performance wise: very good. very stiff. engages instantly. it really is shorter, a lot shorter. the only problem i have now, is getting used to the new pedal location..because it sits way lower now, i always go to where it "used" to be and start trippin because i think my pedal's gone..
2 thumbs up!!
Old Feb 10, 2006 | 07:00 AM
Default Re: (muasboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muasboi &raquo;</TD></TR><TR><TD CLASS="quote">i just bought mine from IAP..thank you!! anyways install for me was 1-10, then being the hardest..i'd have to say 5..just because of the akward position your in, when your under your dash..
2 thumbs up!!</TD></TR></TABLE>
Great to hear your pleased! Thank you for the business. Have fun!!
Old Feb 10, 2006 | 03:41 PM
.water's Avatar
after install you need to adjust rod on madter cylinder? (if so how). and clutch 2 sensors?? under there?
thanks
Old Feb 11, 2006 | 02:06 PM
.water's Avatar
still need an answer about freeplay and adjustment
Old Feb 12, 2006 | 04:07 AM
darrenrowe's Avatar
GREAT PRODUCT! REALLY HARD WITH THE ADVANCED EXTREME PRESSURE PLATE THOUGH... BUT NO ISSUES ON ADJUSTMENT YET. EASY INSTALLATION (10 MINS INCLUDING BLEEDING) ON THE TEG. AND WORKS JUST FINE WITHOUT ADJUSTMENT
Old Feb 13, 2006 | 01:05 PM
.water's Avatar
well..can anyone post a pic of cmc installed??
Old Feb 14, 2006 | 01:00 PM
.water's Avatar
picture of installed please!!!! (inside)
TOO MUCH TORQUE
Dec 25, 2011 03:13 PM
4175017
Sep 22, 2006 10:37 AM
turbojohnny
Sep 22, 2006 10:35 AM
Elfstone
Jan 11, 2006 10:20 AM
sunlei
Mar 18, 2004 08:36 PM
