Check engine light code "92" what does it mean?
I have a honda civic with a 96 LS motor in it.. the ECU is a P75 OBDII. When the check engine light comes on you acn check it with the service connector... and i did and i get
9 long flashes and 2 short... 92, but when you go to the top where the FAQ's are and look at the codes... there is no 92?
help?!?
help?!?
i am not sure but i think that it is not a code 92 i think it is a code 9 and a code 2 but i dont reall kno i willlet someone else give there .02 good luck tho
