type r tranny on a gsr
You would get a shorter gears and lsd, i have a b16 tranny their their same except for the lsd, its night and day,
remember its going to waste a bit more gas if you drive highway a lot.
what are you planning to do with your car tho? Turbo or natural aspiration? I dont think type R trannies are too good for boosting. Gears are too short for my taste. Well short gears are more fun but waste too much gas. 80mph at 5K rpm.
short gears are hella fun with N/A cars. but once you start making over 300whp or so on boosted cars, traction soon becomes a big issue and so does over revving at times.
i just did a type R tranny swap into my b18b1 and what i did was take my 3rd 4th and 5th gears out of my LS tranny and swapped them into the Type Rtranny, everything went smoothly.
cant wait to get everything back into my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">You would get a shorter gears and lsd, i have a b16 tranny their their same except for the lsd, its night and day,
remember its going to waste a bit more gas if you drive highway a lot. </TD></TR></TABLE>
Ever look at the gas mileage between the LS, GS-R and Type-R?
It's funny how both the Type-R AND the GS-R get BETTER mileage than the LS. That must be wrong because they both have shorter gearing, right?
It's mis-information saying swapping tranny's will net you lower mileage.
Read and follow the links Michael Delaney posts
http://www.team-integra.net/fo...51883
This is some details of the actual ITR tranny into a GSR.
http://www.team-integra.net/fo...21250
This is the actual gear ratio's between the diff tranny's.
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
A really good post on Gear Ratio's and torque.
http://www.team-integra.net/fo...38223
Don't talk about something you've just heard from a guy who had a friend who had a buddy who said this or that was good or whatever. Read and learn for YOURSELF.
Hope this helps.
http://www.team-integra.com Has lots and LOTS of great information.
Hope this helps.
Guest
Posts: n/a
I'm thinking of going ITR LSD with my GSR... she def. needs a new tranny... not boosting for a while, but what could I do to remedy the short gears if i eventually do decide to boost?? also... I do a lot of highway driving... cant I just replace the final drive?? I'm not ok with doing 80 mph at 5k rpm
i appreciate the info lots man...i ordered the ITR LSD tranny last night for my 98 GSR. Ebay had a hell of a deal 1680.00. i guess only problem i have is that i drive to see my dad every other weekend which is 4 1/2 hours of highway driving...lol nehow...thanx for all...will repost when its installed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyteggy »</TD></TR><TR><TD CLASS="quote">i just did a type R tranny swap into my b18b1 and what i did was take my 3rd 4th and 5th gears out of my LS tranny and swapped them into the Type Rtranny, everything went smoothly.
cant wait to get everything back into my car</TD></TR></TABLE>
well wasnt that stupid?
as far as im aware of 1st and 2nd gears in b-series transmissions are all the same.
its the 3rd, 4th and 5th that differ.
1st and 2nd are fixed gears...................
so the only advantage now is the type-r lsd...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdc2jdm »</TD></TR><TR><TD CLASS="quote">what are you planning to do with your car tho? Turbo or natural aspiration? I dont think type R trannies are too good for boosting. Gears are too short for my taste. Well short gears are more fun but waste too much gas. 80mph at 5K rpm.</TD></TR></TABLE>
anddd god damnit with this stupid talk about type-r/b16 transmissions are not good for boost because the gears are too short.
ill say it again.. with an ls transmission the myth is you will be boosting "longer" since its a longer gear.
not true.. you will accelerate slower and will fall out of boost more than likely during a shift.
b16/type-r transmissions will bring you through the gear faster, and yes.. youll still be boosting while going through the gear faster.. and you will remain in boost during a shift..
if you have problems with traction, there are many other solutions rather than putting a tall geared transmission in your car.
what a waste of an itr tranny....
i mean, i can understand taking out 5th and putting the ls 5th in for highway, but why the hell would you take out the wonderfully short 3rd and 4th??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSRracing95 »</TD></TR><TR><TD CLASS="quote">
yes it's true that you'll accelerate a lot faster with shorter gears, but you have obviously never had a car with over 350whp and almost the same amount of torque have you? it's almost impossible to do anything about it on the streets and the only remedy for that sometimes is taller gearing. hench the reason why many people prefer the slightly taller gearing of the B18c tranny over the B16/ITR tranny. Even at the tracks with some 22x8x15 M/T's i still spun 1st and 2nd gears all day.
your dumb
your dumb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">
That pedal on the right has MUCH influence over wheel spin, especially on the street. If your skills don't allow for you to control it that way, pull out in 3rd gear.
