I CAN'T FIND THE SENSOR!
Old Mar 25, 2002 | 06:20 PM
allmotorEG-SI's Avatar
Default I CAN'T FIND THE SENSOR!
I have done a search and it didnt' help all that much. I have a 91 crx hf and need to find the vss sensor because i'm getting code 17. please help me find it pics would be great too. thaks
Old Mar 25, 2002 | 06:33 PM
vhd's Avatar
vhd
Default Re: I CAN'T FIND THE SENSOR! (CAMAROCRUSHER)
the vss is located on the topside of the tranny. if you look in the back of your engine where the rear tranny mount is, then you'll see it. your car uses a cable vss instead of the newer electronic vss, i'm guessing you have done a engine swap and the ecu is trying to look for the electronic vss
Old Mar 25, 2002 | 07:38 PM
90civichbsi's Avatar
i have a 90 civic si, my speedo hasnt worked for about a year, how hard is the electronic vss to change, i also have a code 17
SiR_Injected
Oct 21, 2007 07:24 AM
Darth_Accord90
Mar 7, 2007 01:54 PM
kslimm0714
Apr 18, 2006 04:11 PM
justing
Nov 4, 2003 02:40 PM
allmotorEG-SI
Dec 15, 2001 12:37 PM
