da cluster in 88?'s
Old Feb 7, 2006 | 07:17 AM
quis84's Avatar
Default da cluster in 88?'s
i have been searching for the wiring info for a da cluster but i keep getting the info to the 99 si swap. i wanted to know if any one had the wiring layout for the da or pics with it installed with comments on what they had to do to get the cluster to fit thanks
Old Feb 7, 2006 | 08:05 AM
donaldmejr's Avatar
Default Re: da cluster in 88?'s (quis84)
I just installed a da cluster a few days ago and It was a b**** and then I found a 94-97 integra cluster in a junkyard and I dont look back on the da cluster
but here you go
Quote »
90-93 integra ls pinout
PIN Wire Color Wire Function
A1 Yellow/Red Seat Belt Reminder Light
A2 Green/Red Parking Brake Switch Light
A3 Green/Black Hatch Open Indicator Light
A4 Green/Red Low Fuel Indicator Light
A5 Yellow/White Fuel Gauge
A6 Yellow/Red ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7 Red Gauge Lights, Dash Light Dim
A8 Empty
A9 Red/Black Gauge Lights
A10 Green/Yellow Right Turn Signal Indicator
B1 Green/Blue Left Turn Signal Indicator
B2 Red/Blue High Beam Indicator
B3 Blue/Red ABS Indicator Light
B4 Blue Tachometer
B5 Green/Red Door Open Indicator Light
B6 Yellow/Green Engine Coolant Temp Gauge
B7 Black Ground
B8 Yellow Ignition Power
B9 Green/Orange Malfunction Indicator (Ck Eng.) Light
B10 Black/Yellow Charging Sysem
B11 White/Blue Charging System (Battery) Light
B12 Yellow/Red Low Engine Oil Pressure Light
C1 Red Cruise Control Unit
C2 Red/Black Gauge Lights - Cruise Control Dimming Circuit
C3 Empty
C4 Empty
C5 Black Cruise Control Ground
C6 Empty
C7 Yellow Ignition Power for Cruise Control Unit
Old Feb 7, 2006 | 08:29 AM
quis84's Avatar
thanks man i dont have cruise control so i do not have to clip c correct and how long did it take u and what did you do to get it to fit under the hood
Old Feb 7, 2006 | 10:14 AM
123_vtec's Avatar
Here is the link of DA cluster pics installed in a CRX. Let me know if you need any help. LOl Forgot to put the link. Lol here it is.
https://honda-tech.com/zerothread?id=1513450
donaldmejr
Jan 20, 2021 10:23 PM
afterdark
10
Feb 25, 2012 09:31 AM
vtecn8ive
27
Nov 4, 2007 05:41 AM
WWDTrackRacer
Jan 11, 2006 07:08 PM
Gumbey75
Mar 25, 2005 08:20 PM
