H22 S-spec head swap
Old Feb 7, 2006 | 01:51 AM
Jynxeh's Avatar
Default H22 S-spec head swap
Hi guys,
Swapping an H22a into my Rover 600 later this year, currently collecting parts.
I came accross an S-Spec H22a from a 1999 Imported lude.
My block is a ~1994 H22a Jap import (im in the UK) so the 197bhp version. From what I can gather the S-Spec block pushes 220bhp through different cams and a higher compression ratio (11 instead of 10.6 iirc). What I cant work out is if the head is actually ported to a better level?
Also I was under the impression that on the whole, the first character of the engine code is _generally_ a sign the heads are interchangable. However I recently checked for another project and its clear the H22a and H23 have a different arrangement for the exhaust manifold.
From what I have read here - https://honda-tech.com/zerothread?id=922422 - the cams should just drop in, but is that still the case even with different generation engines?
Sorry for the waffle.
Cliffs:-
1. Does s-spec head have better porting than normal H22a
2. Will a '99 s-spec head fit on a '94 H22a
3. Do the cams just swap across
4. Is any of it worth it without having the higher compression ratio.
Old Feb 7, 2006 | 08:30 AM
2point6's Avatar
Default Re: H22 S-spec head swap (Jynxeh)
1. There are minor changes to the casting in this head. I can only verify this by observation... no actual measuring. The casting looks "smoother" and more refined. It is possible that Honda simply improved on the casting with the later models.
2. Yes. Use the head gasket for the year of block used.
3. Yes.
4. Higher compression works well with the "S" cams, but not 100% needed. A good tune would be helpful. If you want to bump the compression up, mill the head .010"
Old Feb 7, 2006 | 09:49 AM
SteveoBA8's Avatar
Default Re: H22 S-spec head swap (2point6)
http://asia.vtec.net/beystock/honda/preludes/
Old Feb 7, 2006 | 12:51 PM
mgags7's Avatar
wow thats cool....from what that sounds like they did some pretty nice stuff to the head....and a 57mm stock exhaust....wow....
Old Feb 9, 2006 | 01:45 AM
Jynxeh's Avatar
SteveoBA8: Cheers for that, but I did find that link on Google.
Well I decided against it in the end, was on Ebay and I didn't like the looks of the seller. Lots of car part scams on UK ebay atm, not worth the risk.
Thanks guys
Old Feb 9, 2006 | 06:56 AM
thedread's Avatar
Default Re: (Jynxeh)
You can still get improved compression by slightly milling the head like 2point6 said.
PS Tell Burley to start Ricardo Fuller as he is finally full fit (after 2 years of problems)..you will win more games.
Old Feb 9, 2006 | 10:29 AM
Jynxeh's Avatar
Heh, Ill pass that on!
tbh if he starts playing well, we will just sell him anyway
2point6: You got your engine specs online anywhere?
mozzandherb
Jun 22, 2011 07:55 AM
EGR95
Sep 9, 2009 05:20 AM
SiRTifiedacc
Jul 27, 2006 07:38 PM
Godspeed94
Jul 20, 2005 12:23 PM
0ptimus prime
Apr 25, 2003 07:19 AM
