Wiring for Sohc Vtec
im sure there have been many posts about this topic but i just want to be 100% sure on my swap and that nothing goes wrong although im am sure something will....im swapping a Sohc Vtec ZC into my 91 dx civic 4door and have no idea how to hook up the wires for vtec or where they are...i have seen crappy diagrams for it and they have helped me a tiny bit but i was wondering if anyone has any good websites/diagrams/ or instructions on a how to wire the Vtec for my engine.....i have every possible thing i could need for my swap..and take in account i am doing a DPFI to MPFI conversion along with a obd0 to obd1 conversion harness into my P28 ECU
Do a search on google, and you will find a dpfi to mpfi, and if you have q's along the way you can call us... If its worth it to you, you can have the harness done by us
Ryan
Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc 4door Rye »</TD></TR><TR><TD CLASS="quote">im doing the DPFI to MPFI conversion myself i got that and the obd0 to obd1 but i haven't a clue bout wiring for vtec</TD></TR></TABLE>
What obd1 conversion harness do you have? They usually have the vtec wires already in the harness..
The easiest way i've seen to do what you're doing is Boomslang's DPFI OBD0 -> MPFI OBD1 conversion. Runs all the wires for DPFI, VTEC, and the new O2 sensor. Makes it really easy. All you have to do is cut and paste
I'm sure Rywire offers a similar product as well. I highly recommend both Rywire and Boomslang.
where does the wire for vtec come off the engine? my conversion harness already has it in it but im just not sure what wire it is or how many are involved...on my conversion harness it says 2 wires (Vtec solenoid signal and Vtec pressure switch signal)....where are these wires located coming from the engine on a Sohc Vtec ZC?
my obd0 to obd1 conversion harness has 13 wires i have to splice and solder
1 02 signal heater
1 02 sensor signal
1 vtec solenoid signal
1 vtec pressure switch signal
1 intake bypass signal (if used)
1 knock sensor signal
2 powers
3 grounds
1 service check signal
1 02 signal heater
1 02 sensor signal
2 powers
3 grounds
The VTEC solenoid is on the back right of the head. The solenoid is like a cylinder shape and has a clip hanging off of it by 1-2 wires and then the other clip is screwed onto the cylinder. You'll need the clips from an OBD1 car in order to solder the conversion harness wires to. I got mine from a local performance shop for ~15$. The same goes for the O2 sensor, though you can just solder directly to it if you like. You don't need the knock sensor if you're using a P28 ECU, btw.
JdM_HoNda
Jul 9, 2003 10:44 AM
