Repair Time
Old Feb 6, 2006 | 08:43 PM
OHmyGAS's Avatar
Default Repair Time
I got my 95 Accord EXi about a month ago from a friend's friend. Although my expectations was high about the car, i knew that it would have some things needed to get repaired. Here are some things i noticed:
The tail lights dont get turned off even if i turn off the car, sometimes it turns on after a few mins by itself. im not sure if its the sensor or if my breaks are stuck of some sort, had to jump start the car twice because the battery was drained because of this.
I can hear a screeching sound everytime a press down the clutch, i goes silent after i release it. Im not sure if its just the release bearing or something worse.
Thanks
Old Feb 6, 2006 | 08:46 PM
YeuEmMaiMai's Avatar
Default Re: Repair Time (OHmyGAS)
first problem is brake switch
second problem is you need a new clutch
Old Feb 6, 2006 | 09:04 PM
OHmyGAS's Avatar
Default Re: Repair Time (YeuEmMaiMai)
As in a new clutch? or just parts of it? Getting a new one will be quite a big damage to my pockets. hehe.
and oh yeah, i realized that my front wheels aren't aligned, probably this is one cause why my brakes are stuck. The mechanic told me that the tie rod and rack end needs to be replaced already.
Old Feb 6, 2006 | 10:16 PM
new clutch and it won't be as expensive as a new auto. I jsut dished out 3.2K for my trans.
Old Feb 6, 2006 | 10:59 PM
Dmc1's Avatar
Remember when you replace the clutch to change the release,throwout bearing to.
Jamesflo
May 3, 2012 07:04 AM
levaughnt
Honda Civic (2006 - 2015)
Jul 29, 2011 06:49 AM
eclecticteg21
Dec 17, 2004 06:37 PM
