Timing belt tensioner problems
this is not a normal problem. do you have an auto or manual tensioner? people will recommend converting to the manual if you have an auto, but honda has recently developed a new auto tensioner which is less prone to breaking tha nthe previous design.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer »</TD></TR><TR><TD CLASS="quote">this is not a normal problem. do you have an auto or manual tensioner? people will recommend converting to the manual if you have an auto, but honda has recently developed a new auto tensioner which is less prone to breaking tha nthe previous design.</TD></TR></TABLE>
where did you get that info?? wanna share the link or somethin??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedbird »</TD></TR><TR><TD CLASS="quote">I just had the timing belt tensioner replaced for the SECOND TIME!!! Is this a typical problem I'm going to have to deal with or is it just bad luck? thanks for any imputs...</TD></TR></TABLE>
I just replaced mine. But it shouldnt go out within 2 yrs (2) of them that is. have you taken it to honda and ask them why it went out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">where did you get that info?? wanna share the link or somethin??</TD></TR></TABLE>
i heard it from a tech at honda. the guy also happens to be a close friend, so i trust him. he has never pulled my leg before.
just convert to a manual tensioner, i bought all new h23 manual tensioner parts, wasn't too pricey, better that frying the motor from a failed auto slippage.
and I am not so sure about the "New tensioner" ask your "close" friend where he heard that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer »</TD></TR><TR><TD CLASS="quote">i heard it from a tech at honda. the guy also happens to be a close friend, so i trust him. he has never pulled my leg before.</TD></TR></TABLE>
so is this conversion something my normal mechanic can do or do i have to take it to a performance shop? and how long does it usually take to do it?
yep h23 already rocks the manual, I didn't find it to be hard at all, of course my motor was out, i would deem it very hard to do with the motor in (inside a civic) getting proper tension with the manual 1 took a couple trys, it was either too much or not enough, but once you see the manual vs the auto 1 in person you should see it won't be that hard, most of the rotating mass, balance shaft crap was removed while i was at it.
my friends owns a race shop, and has a 600hp lude, before reaching those #'s his motor crumbled twice from an auto tensioner failing. . .
i highly recommend the switch
patastinky
Jul 13, 2004 07:47 PM
