why are my axles binding?
Old Feb 6, 2006 | 06:22 PM
oreomonster2's Avatar
Default why are my axles binding?
i have an 89 crx and im trying to finish my b16 swap. but the axles are binding when the cars is off the ground but but not when its on the ground. i got the 90-93 integ axles are these not right? and is there a way to fix it or is it normal?
Old Feb 6, 2006 | 07:28 PM
Redline130's Avatar
Default Re: why are my axles binding? (oreomonster2)
What tranny do you have? S1? J1? Y1? Did you remove the dust rings on the hubs and the plastic rings on the ends of the axles?
Old Feb 7, 2006 | 07:56 AM
jdmcars.com's Avatar
If you don't have any binding troubles with the car is on the ground -don't worry unless you plan to drive in the air
Axels go accordlying to what transmission and mid-shaft being used along with what engine mounts. S1, J1, Y1, YS1 or A1 would be the types the could be use -unless you are using hydro.
Normally a car will bind when placed on the ground more than when in the air -?
Old Feb 9, 2006 | 08:02 PM
Default Re: why are my axles binding? (Redline130)
I have the a1 i think. A shop did it cuz i didnt have the time and they said it was the first time theyve ever seen that happen. i was just wondering if it would cause a problem or not.
Shonda
Oct 18, 2006 07:57 AM
jordanb1
Dec 26, 2005 08:58 AM
.Grimace
Sep 23, 2005 12:38 AM
steronz
Apr 5, 2005 02:41 PM
