rubbing, scraping.. ahhhh
Old Feb 6, 2006 | 01:46 PM
Juccord's Avatar
Default rubbing, scraping.. ahhhh
I have a new sound that ive never heard before coming form my car, just noticed a couple days ago, and it just keeps gettin worse. I do have 2 bad axels, bad tie rod ball joint on front left, and a blown bearing in the right rear, so im hoping its gonna be assosiated with one of those. I think it is the bearing, but its not the useual sound, and its from the opposite side of the turn.
When I turn right the sound is created, not when I turn left, wich I know is usually the case. its not a whinning like a bearing, like a scraping actually, sounds like brakes do when there goin bad...
any Ideas.?
Old Feb 7, 2006 | 12:25 PM
Juccord's Avatar
Default Re: rubbing, scraping.. ahhhh (Juccord)
any Ideas.?
Old Feb 7, 2006 | 05:24 PM
P_Adams's Avatar
Either a Dust Shield has bent, or you've caught a stone (pebble) between the brake rotor and the dust shield behind it. It will almost sound like you're metal/metal with the brakes.
Check the Brake pad Wear sensors on both sides. You could have one just to the point of touching.
Sounds like it's time for some long overdue maintaince
P
Old Feb 12, 2006 | 07:14 AM
Juccord's Avatar
Default Re: rubbing, scraping.. ahhhh (P_Adams)
Well I actually just did all my brakes, so I know for sure its not the brakes, I pretty sure it is the r/r bearing, cause when im driving and turn just a bit at higher speeds, the typical "hmm" or "bzz" or "brapzzzrrr" whatever, starts happening at slight turns, the weird part is that its when I turn the opposite way. I know when I was changing the brakes in the back, the hub was pretty loose. Hope fully changing the bearing will fix this problem, then 1 million other things to go.
Thanks
shawn_crx
Oct 14, 2009 10:07 PM
gsl_05
Jul 25, 2007 04:47 PM
BLacK FirE
Feb 24, 2007 09:31 AM
Funkin Flux
Jan 25, 2006 05:43 PM
Oracle17
Oct 1, 2004 10:37 AM
