89 Accord LXI 2.0 CEL
Old Feb 6, 2006 | 01:12 PM
Say Bye's Avatar
Default 89 Accord LXI 2.0 CEL
My dad has a 91 accord lxi and the CEL just came on. Can someone please tell me how to read this? ie-where to "bypass" the ecu to make the CEL flash
I've done searches but couldn't find anything that helped. Thanks in advance
BTW..I understand Autozone will check it for free, but the car want run long enough to make it there
Modified by Say Bye at 2:27 PM 2/6/2006
Old Feb 6, 2006 | 02:54 PM
hondadude's Avatar
Default Re: 89 Accord LXI 2.0 CEL (Say Bye)
For your 89 LXI you'll need to look under the rear of the drivers seat to find the ECU that has a flashing LED when the ignition switch is turned on.
For a 90-93 accord try this link
http://members.troublecodes.ne...n.jpg
What is the reason for title of the post to be 89 LXI, then ask a question about a 91 accord??
Old Feb 6, 2006 | 07:08 PM
Say Bye's Avatar
Default Re: 89 Accord LXI 2.0 CEL (hondadude)
Sorry, I mean *89*. Thanks for the help, i hope to have a code by tomorrow.
Is there a good source for looking up the codes on a 89?
Old Feb 6, 2006 | 08:01 PM
ericw's Avatar
Read this. http://www.3geez.com/forum/showthread.php?t=26342
Old Feb 7, 2006 | 05:23 AM
Say Bye's Avatar
Default Re: 89 Accord LXI 2.0 CEL (ericw)
Just what I needed! Thanks man
Old Feb 7, 2006 | 02:34 PM
Say Bye's Avatar
Ok here is another newbie question, when counting the flashes on a 89, do you simply count each time the light blinks or do you have to do the short and long thing?
When you turn the ign. on, you get one blink..pause...six blinks..pause...six....etc.
Would the be code 6?
Old Feb 7, 2006 | 07:38 PM
ericw's Avatar
Yes, you just count flashes there are no long or shorts. If it flashed 6 times then paused and flashed 6 times again then it is code 6. At least it sounds like an easy problem since its the coolant temp. sensor.
Matt Doan
Apr 3, 2016 07:42 PM
termite1r
Oct 24, 2012 07:31 AM
dansaleen_04
Dec 2, 2010 03:07 PM
95cxh22a
Apr 12, 2008 03:57 PM
