2000 Fully Built Integra Type R - over 50k in upgrades - Very Clean - CA
I have spent 5 years building this car and I have spent countless hours working on this car, but in the last 8 months it has just sat in my garage. I have a daughter now and do not have the time for my old baby (ITR) anymore. I need to sell it as soon as possible and would like to find someone that can really appreciate all the time, effort and of course money that has been put into this one of a kind car. I have received tons of emails looking for a price and I think 20k or just over is completely reasonable for how new all the parts are and the low mileage.
I have gotten many people interested, please email me at splitpeafu@aol.com or call me at 1-408-482-9442.
-James Abrams
Just over 800 Miles on the Engine – “Broken In”
Just over 40k Miles on the Transmission
Just over 800 Miles on the Paint – Everything but roof
Just over 3000 Miles on Brakes
Just over 3000 Miles on Suspension
Just over 3000 Miles on Wheel Bearings
Under 37k Miles on the Chassis.
Engine Block
LS Block 2.0L – Block $400
Thermal Dispersant Coated Block Exterior - $150
RS Sleeves Open Deck Iron Ductile Sleeves – 84.5mm - $900
Weisco 9:1 Compression Thermal Coated and Dry Film Coated Pistons - $400
Balanced LS Crank - $400
King Race Bearings - $100
Eagle Connecting Rods – Balanced - $400
ARP Rod Bolts and Head Studs -$100
Golden Eagle Oil Distribution Block Adapter - $75
Energy Suspension Engine Mounts - $50
Energy Dynamics Engine Breather Kit - $175
Drilled and Tapped Knock Sensor - $40
High Output Rewound Alternator - $150
New Honda Oil Pump and Water Pump - $125
Z10 5 quart Baffled Oil Pan and Pickup - $400
Block Assembly: $725
Block Total: $4590
Engine Head
GSR Head Cast - $300
Thermal Dispersant Coated Head Exterior - $100
Port-Flow Stage 3 Port and Polish - $700
Port-Flow High Pressure Springs - $200
Port-Flow Titanium Retainers - $200
Supertech .5mm oversized Intake Valves - $120
Supertech .5mm oversized Inconel Exhaust Valves - $145
Thermal Barrier Coated Valves and Combustion Chamber - $150
Cosmetic MLS Head Gasket - $150
RC Engineering 720cc Injectors - $300
JG Edelbrock Intake Manifold – Thermal Dispersant Coated - $300
Crower Stage 2 Turbo Cams - $700
STR Fuel Rail - $150
STR Cam Gears - $150
JDM Integra Valve Cover - $150
Mugen Oil Cap - $50
Head Total: $3865
Turbo Kit
Thermal Barrier Coated LoveFab Tubular Manifold and Downpipe - $1500 total
Thermal Barrier Coated T-61 Turbo - $900
Thermal Barrier Coated Tial 46mm Waste gate - $300
Thermal Dispersant Coated Spearco Intercooler - $500
Thermal Dispersant Coated Intercooler Piping - $200
Blitz Blow-off Valve - $150
Custom Bozz-Speed full 3in Titanium Downpipe Back Exhaust - $1500
Hose Techniques T-Clamps and Silicon Couplers - $150
Greddy Profec-B Boost Controller with Steering Wheel Remote - $250
HKS Air Filter - $150
Turbo Kit Total: $5600
Transmission
Integra LS Transmission - $400
ATS 16 Plate Differential - $1100
Clutchmasters Stage 3 Clutch - $350
Clutchmasters Aluminum Flywheel - $250
ARP Flywheel Bolts - $30
Energy Suspension Shifter Mounts - $20
Transmission Total: $2150
Miscellaneous Engine
Hondata Stage 4b, now S100 chip - $500
P73 ECU with obd1 Conversion - $300
GM 3 bar Map Sensor - $90
C&R Aluminum Radiator – Thermal Dispersant Coated - $400
Cusco Oil Catch Can – Valve Cover - $90
MDS 6A Ignition - $100
NGK Spark Wires - $100
MSD Blaster Ignition Coil - $50
J&S Ultra Safeguard - $400
Miscellaneous Total: $2030
Exterior
C-Westin Full Body Kit including the front and rear bumper and side skirts - $1500
JDM Front End with Metal Fenders and Radiator Support -$2400
C-Westin Carbon Fiber Hood with Unpainted Vents - $900
Mugen Adjustable Rear Spoiler -$400
JDM Honda H emblems -$80
JDM Rx Folding Mirrors - $200
New Paint - $3000
Total
Interior
Cusco 6 Point Bolt in Roll Cage - $600
Spearco Corsa Fiberglass Bucket Seats - $1200
SeBelt 4 point harnesses - $250
Mugen Bucket Seat Mounts -$300
Defi-Link Monitor
Defi-Link Boost Gauge
Defi-Link Oil Pressure Gauge
Defi-Link Oil Temperature Gauge
Defi-Link Water Temperature Gauge
Defi-Link EGT Gauge
Defi Gauges total - $1100
Apexi Digital Rev/Speed Monitor w G sensor- $200
Apexi Turbo Timer -$100
J&S Display -$100
Auto meter Air Fuel Gauge -$50
Custom Carbon Fiber Panels -$300
C’s Short Throw Shifter -$250
Suspension / Brakes
Racing Hart 17x7in CP-035 Real Racing Rims -$2000
Bridgestone Potenza S03 215-40-17 Tires -$1000
Cusco Zero-2 Full Race Coil-over Suspension -$1800
Wilwood Dyna-Lite Front 4 piston Calipers from Fastbrakes
Two Piece Cross Drilled Front Rotors – 11in
Two Piece Cross Drilled Rear Rotors – 10.6in
Brake Setup Total -$1700
Skunk 2 Extended Wheel Studs -$150
Cusco Front Carbon Fiber Strut Tower Bar -$150
Cusco Rear Carbon Fiber Strut Tower Bar -$150
Comptech Front and Rear Camber Kit -$300
Kyokugen Heptagon Lug Nuts -$70
Audio
Panasonic Cd Deck -$200
4 JL 8w3 Subwoofers in custom box -$400
Phoenix Gold 500 watt Amp for Subwoofers-$250
Ample Amp for Speakers -$200
Voodoo 1.5 Farad Capacitor -$300
MB Quart RSC and RSD Component Speakers in front and Rear -$500
Clifford Alarm -$900
-James Abrams
Engine Block
Block Total: $4590
Engine Head
Mugen Oil Cap - $50
Head Total: $3865
Turbo Kit
Transmission
Exterior
New Paint - $3000
Total
Interior
Defi-Link Monitor
Defi-Link EGT Gauge
J&S Display -$100
Suspension / Brakes
Audio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar »</TD></TR><TR><TD CLASS="quote">what are all the switches for??</TD></TR></TABLE> naaaaawwwzzzzz baby!!!
No they're not.
When you search your name under recent threads 5 threads still come up. All you have to do is bump them, they aren't lost.
https://honda-tech.com/zerothread?id=1499737
https://honda-tech.com/zerothread?id=1504913
https://honda-tech.com/zerothread?id=1515880
https://honda-tech.com/zerothread?id=1518371
https://honda-tech.com/zerothread?id=1510344
My recent topics shows 4, 3 under the vehicles and one under the forced induction forum. Two of the three were very far on the pages so I figured they were dead. I wont post anymore I promise.
Bump, still need to sell this thing, email me at splitpeafu@aol.com if you are interested.
bump, its still for sale waiting to hear back from a few people that are about to get a real great deal.
400WHPITR
Jun 8, 2006 07:57 AM
400WHPITR
Jan 30, 2006 11:25 AM
eg360B
13
Jul 1, 2004 06:56 AM
